jlb85
- Mar 31, 2008
- 734
I have had success with APC at 4:1 using a brush like this one:
Clean Vent Kit
But for door jambs, underhood, and heavy greasy places you should try something like Meguiar's Body Solvent (Meguiar’s Body Solvent, 1 Gallon, removes tar, wax, and stubborn grime from exterior car surfaces. Concentrated cleaner safe on exterior surfaces.).
Google "Kevin Brown Work Truck Detail" and read the process for the door jambs. It has inspired me to use the stuff, and it works so well you will find no need to use APC there anymore
I still use the brushes above, and I follow up with either an ONR rinse with a spray bottle, or just hose it off with the foam gun.
Here are some pics I took of the process on my personal car. Again the process:
1-Apply Body Solvent via spray bottle (be ready to wipe adjacent areas for BS overspray, like dashboards, leather seats, interior door panels).
2-Agitate with brushes of your choice.
3-Quickly wipe up the places you can reach easily with an old MF towel (they will never look clean again).
4-Spray soapy mix into area, try to rinse out all you can.
5-Wipe dry with a clean, old, MF towel. Try to reach everything. This will leave the surface ready for sealing.
6-Seal with your choice of spray-on LSP. AIO by hand the larger areas if you wish. This keep all that junk from accumulating there again.
Before:
After:
(this one could use another hit on the black rubber)
Clean Vent Kit
Before:
After:
