Meg's MF Correction System
I've always been tempted to tey their system out, all I hear is good.
I use a small brush to clean off the product and fluff them up, I tried the compressor too but find the brush works better and faster.
Do you use a typical foam pad cleaning brush or some other type?? Can you elaborate on the technique you use to clean MF pads vs foam pads?? I've been wanting to give them a try, but don't have an air compressor to blow out the pads.
would these pads with po85rd w/ DA be enough for a mercedes CERAMIC clear coat with minimal swirls since foam pads are no bueno? (sorry to thread jack)
No.
CERAMIC clear is very hard and realistically you might need the DA compound just to remove swirls from it.
Po85rd is a true final finishing polish that you use after a true polishing step to pull out the very last ounce of gloss and perfection. But Po85rd very little cut at all.
