Megs MF pad on curved panels
SR99
Thinking about trying some MF pads. In looking at the Megs MF, the foam interface looks fairly thin and stiff (dense) so I'm wondering if foam pads are still needed for curved areas, especially concave, since foam pads are more compressible and would seem to conform better.
Generally my question is are the Megs MF pads somewhat limited beyond flat panels, or are they a full car solution?
I use 5" Megs mf pad on all all panels, concave, flat, convex. they do serious correction. But if your looking for perfection, you may not be able to get rid of major defects in the concave panels, but if you will use their 3" mf cutting pad, that may just do the trick.
