I know everyone is going to experiment but with the microfiber setup, its best to stay with what has been tested. Switching out 300 and 301 with 105/205 defeats the purpose of the microfiber system. Use the system as a kit or use 105/205 with the corresponding foam pads.
To OP: Give it a shot. I use it all the time when I need more cut.
I disagree that you defeat the purpose by using 105/205. This system has tons of potential and can do alot more if you think outside the box. If you think about it from the abrasives in the buffing liquid, All use the SMAT (super micro abrasives technology) so you can follow the directions they say for d300 and replace it for 105. You potentially will get more cut but with that you may get more hazing.
You certainly are not defeating the purpose by substituting these buffing liquids, you will possibly get different results such as more cut and/or more hazing or less cut and/or better finishing. If you have all 4 buffing liquids and the MF discs give it a shot and see for yourself.
Hmmm, sounds like im going to have to change my mindset and start experimenting with the collection of products that I have.
good answerrops:
