killrwheels@autogeek said:Now your thinking, and yes you are correct. Everyone talking about layers of NXT is likely just removing the old. Even the Spray Wax Booster appears to contain kaolin.
I'm kinda hard headed....
Darren F said:Well im waiting on my order of FK1-425 so I have that covered...What do you think if I were to use Pinnacle Liquid Souveran Wax every 2 or 3 weeks inbetween the Tech Wax?
Darren F said:opps sorry about duplicating that last post.....what is U.P.P Enhanced Gloss Spray?
Darren F said:So I guess for now I should be OK with the 425....Should I use the 425 and then go over it with a sealant spray? Which of the Sealant Sprays do you prefer or recommend?
Darren F said:The Tech Wax says it eliminates swirl marks, now does that mean it fills them in so you do not see them or does it actually remove them?
justin30513 said:I also have some samples coming from FK1. Very interested in their decomtamination process but have some sealant and 425 coming also. Expect a review.
Darren F said:So then using the Tech Wax on a Black car would be a good idea...If there are any fine scratches or swirls it will remove them
Darren F said:now did it just hide them or did it remove them?
BILL said:i doubt you can get rid of swirls without a p.c with just a wax with fillers as NXT...... i think it just hid them....
