jamores23
- Dec 17, 2008
- 974
why is there "for sanding discs" only 320/500/800/ and 1500 grit but for "finishing discs" there is only 1000/3000. My question is, What would the difference between the "sanding disc" 1500 grit and a "finishing disc" 1000 grit be. Obviously the grit is different but why is one called a finishing disc and the other a sanding disc. Is it fine to go from 1000 grit "finishing disc" to 3000 grit "finishing disc" also, I see that the megs discs dont start cutting immediately it has to "BREAK IN" compared to the 3m discs that cut immediately . How would you break it in or would the 3m pads be a better choice?
