Meguairs Qucik Detailer = 4/10 cut ?
Vifa
Hi,
I always thought of Meguairs Qucik Detailer as a non abrasive product - then I found this and it has a 4/10 cut on the scale:
Is the M66 Qucik Detailer the same as this one? :
Not the same, M66 is an AIO an the one in the burgundy bottle is just a spray detailer.
Hi,
No.
M66 is an AIO.
If you want a gallon of "quick detailer", get M34 Final Inspection.
M66 is what I use for a cleaner wax. It's light bluish green thick liquid.
Good to know, thank you all for the answers.
Btw, with regards to the M66:
Since the Speed Glaze M80 has been discontinued, should I consider the M66 as substitution ?
The M80 also had a 4/10 on the cut scale.
I haven't used M80 in a long while, M66 is a pretty good cleaner wax that will clean paint and leave some protection. The Megs D151 is a more modern AIO, it can cut more(depending on pad) and is easy to work with along with laying done some protection.
M205 would be another fine substitute.
I suppose it would!
I always forget that M80 had a paint shop safe sealant in it. I believe M66 has more protective qualities, but the protective element being both a wax and sealant? Not sure. Don't really care either, as long as it keeps doing the excellent job!
