Meguiars are so wrong..
6LS2
I was looking over their forum the other day and I did some research on wetsanding. " Mike Phillips " the Administrator of Meguiars aka the " pro " has said several times " You cannot remove sanding marks with a DA " And that it HAS to be done with a rotary. On one of their videos on youtube it shows them wetsanding a hood at Meguiars, then they try remove the sanding marks with a Heavy cutting pad and M83 and it did not remove them, because of this they think that it can't be done. This should put a smile on some of your faces, and make some of those people that think Meguiars polishes are the best polishes ever look abit stupid.
Today I did some wetsanding on a 2003 Ford Focus. I used 2000 gritt. After sanding I got out my PC7424, Lake Country Yellow CCS pad and Pinnacle XMT #3. Yes thats right, XMT #3, not #4. And guess what? It removed them in the first pass.
So I just thought I'd share with you all, what Meguiars couldnt remove after one pass, XMT could, and it wasnt even a heavy compound polish!
XMT > Meguiars. :)
Thanks for reading!
6LS2
You'll still see them in certain light. XMT 3 on a DA is not going to completely remove 2000 grit sanding marks in one pass. I don't doubt you got some gloss back in the paint, but there is absolutely no way you completely removed them like that. You can show me all the pictures you want, but I'll guarantee you I can find them in person.
I did some wetsanding yesterday, and even on a soft honda paint, it took 2 hits of powergloss & lake
country twisted wool on the makita @ 1800-2000rpm to completely remove it..
XMT > Meguiars. :)
Thanks for reading!
6LS2
XMT > Meguiar's > Turtle wax compound...
Well I put it in the sun and looked at it from every angle, and in the garage under strong lighting it was all gone. I know where your coming from, because I didn't think it would remove it, but it did.
The next time I do some wetsanding, I'll try to remember to do 1/2 with the PC & XMT 3 and then the other half with the rotary and show you the difference between glossed over and gone. I suck with a camera though.
When I remove some sanding marks tomorrrow I'll remember to take close pics.
with the correct polishes (menzerna) and pads you are likely to get the job done, what Mike should have offered is it is much quicker with a rotary and done in only a few passes.
Hmm....let me know how this turns out because I need to help a friend use some touch up paint and wetsand/polish afterwards and all I have is a PC7424....
I'm not saying you cant do it with a DA..
I'm saying you can't remove 2000 grit completely with one pass of XMT 3. Even on the softest of paints.
You also need to factor in HOW it was wet sanded.
In other words was the finish sanded until it was dull OR was it only lightly sanded? Did it have the right amount of lubrication, what paper manufacturer, was it old or new paper, etc.
New 2k grit paper is just that, 2000 grit, yet take a used 2k grit paper and it may actually be 2500 or 2800.
Lots of variables here.
Anthony
To add to other posts above, I think you can reduce them a huge amount, but I highly doubt it can be done with XMT 3. I think you you look with a microscope you will find that there are still sanding marks there. I am pretty sure the finish won't be as clear as if you had done it with a rotary. I don't think Mike said it couldn't be done, I he said it couldn't be done in a reasonable amount of time. I have mid terms this week, but I actually have pictures of these micro sanding marks.
Few more thoughts. Meguair's was using a W8006 polishing pad, the equivalent of a white pad, so the test isn't really fair. Moreover, Meguiar's doesn't make claims that they can't back up on all cars/ trucks/SUVs etc.. it has to be "bubba proof".
Exactly. They tell people not to use their cutting pad with the DA PC because their cutting pad is just way too aggressive (it isn't exactly the same as a cutting pad from another brand). Not all pads are made the same; the 7006 was made for the rotary and not PC use as your have to remember most of their polishes were originally for rotary use than adapted for the PC.
Meguiar's products may not be the quickest way of getting things done, but they always deliver what they are promised to do. Remember these products are mostly made for body shops, and let's be honest here, most body shops products need to be as idiot proof as possible...hence the reason Meguiar's first came out with the 80 series (85/84/83/82/81/80) to simplify things, then even dumbed it down even more with the So1o One Liquid system.
Before
After
Thats after one pass of XMT 3 on the yellow CCS pad. Sanding marks are pretty much gone, I had a look under some lighting ( forgot to take pics :( ) and the only thing that remained was hazing..
But you guys must say, for 2000 gritt sanding marks and only one pass of XMT 3, it did a fantastic job..
Yes yes it did do a darn good job for just 1 pass via pc.
Man this is a wicked topic, very good points being brought forward here.
One thing I remember from using XMT 3 is that it hides imperfections quite well. I'm not trying to be rude in any way, now I would have to agree with what has been said about XMT completely removing the 2000 gritt sanding marks...I've never tried to remove wetsanding marks with XMT 3 but I have removed lots of wetsanding marks with Menzerna and even with Menzerna it some times requires at least two passes.
But serously though this is a wicked topick, keep giving feed back...makes for great reading...:righton:
I've tried 3M Cutting Compound to remove wetsanding marks with my ROB PC and I couldn't get it all off, or at least smooth enough. Now, I tried that with an LC Orange Pad and NOT a Yellow Pad; It's quite possible that a Yellow Pad may yield better results...
LS2, you are doing apples and pineapples here. Let's be logical and technical. First, Anthony is correct, you have taken number of variables out of equation and assumed they were identical. That on it's own is bad enough. Second, it's two different clears. Just that throws possibility of any conclusions out of the water. Mike Phillips is correct when making his statement as that is general statement, in general you can not always take wetsanding out with PC. You are correct that sometimes you can. Just because you can sometimes that does not mean you can every time. To be able to say with 100% certainty you need to talk about every time. What he said gives 100% certainty.
I did some wet sanding a while back on a black car. I remember that it took only 2 slow passes with menzerna IP to make the sanding marks hard to see, but I ended up going over the marks 2 times(not 2 passes) end the paint looked almost perfect but I could still see wide valleys, but I mean you really have to looks close.
"I had a look under some lighting ( forgot to take pics
) and the only thing that remained was hazing.."
Basically exactly what I said. You glossed them over. What you're calling hazing is sanding marks still there. I'm sure it looks better than no polishing at all, but they're not gone. Not even close. Like I said, show me all the pics you want, but I'll guarantee you I could find them on the car in 2 minutes or less without knowing exactly where to look. And to call a professional (one that obviously has standards of what his work should look like) wrong on this is just crazy.. But hey, if its good enough for you, thats fine with me.
I'll still never say that you can't take 2000 grit marks out with a PC. But you can't, even on soft paint, get them out with one pass of XMT 3.
