Meguiars D115 As A Quick Detailer?
Sean Ryan
Hi,
I was thinking if you could use D115 as a Drying Aid and a dedicated Quick Detailer?
IMO: You sure can.
I have seen D115's dilution ratios
range anywhere from 4:1 to 20:1.
In this case:
I prefer D115 @8:1 ratio
for use as a QD.
Of course:
Your QD ratio preference may wind
up being different than mine.
IMO: You sure can.
In this case:
for use as a QD.
Of course:
I have been using it at 4:1 it give's mad amount's of gloss and is very slick i really like it :)
D115 is also the best glass cleaner I have used. Only problem I have with the product is that it tends to collect dust, at least around here.
It's very slick has it not got anti static property's to repel dust?
Not in my experience. There might be a lot of silicone or other oils that remain once applied. I only use it for glass now and the dusting is much lower after cleaning with other products.
Lots of dust here so may not be an issue in other places. I use ONRWW as a wash and drying aid for the rest of the car. Very little dust with that product.
What ratio do you use for ONRWW as a drying aid?
I've been using D115 (4:1) as my quick detailer for about a year now on my black truck. I love the way it works and it's significantly cheaper, other than the initial investment for a gallon, than buying $10-$12 individual spray bottles of QD.
I also use it at 4:1 so 1 gallon turn's into 5 gallon's :)
1:16 Really helps improve the sickness and gloss.
Thanks buddy :)
