swanicyouth
- Mar 3, 2011
- 9,388
I'm going to go out on a limb here and make some assumptions. Feel free to disagree.
1. From the best I can tell from the photos, the calipers are factory Brembo, similar to these:
2. The Megs "All Wheel" cleaner product is just a soapy high pH / APC type standard wheel cleaner.
Ok...
Now, the way I see it, there are only a few possibilities of what's really going on here:
1. The cleaner was applied to HOT calipers. I realize OP says this didn't happen - but it sure looks like that to me.
2. The cleaner was left to dry neat on cool calipers.
**** Lets assume for now the calipers' finish is actually permanently damaged and this merely isn't white product residue left that can simply be cleaned off ****
As far as not getting your wheel cleaner on the calipers - that is kind of crazy. These calipers are probably painted or powder coated with a "paint" similar to what's applied to the wheels. Of course if you have nice calipers and are into detailing, you are going to want to clean them when you clean your wheels.
What are you supposed to use, Brake Caliper Soap????
Can you link me to where I can purchase that?
When using any wheel cleaner, you can not apply it to hot wheels/calipers and you can not let it dry on the wheel. You have to work on one cool wheel, rinse it thoroughly - and then move on to clean the next wheel.
If you use this method, you likely can use any wheel cleaner including strong acidic wheel cleaners, without causing damage to the wheel or caliper finish. Some pros exclusively use these types of cleaners on all types of high end cars without issue.
This Meg's product is as OTC as it gets. These products are designed to be safe with most of what's out there - and there are a lot of Brembos out there. I would think if there was some special ingredient in the product that can damage the finish (assuming correct use) - it would have been known by now.
Why wouldn't you try this immediately? This could have straightened out your issue right from the get go.
Then later you actually tried this and were only able to conclude it "might" come off??
Ok...
I tried to rub it off couple of days ago with my fingers (speaking of being super frustrated and little time to spend) and i noticed that it might come off !..
