Cincy Colorado
- May 25, 2011
- 17
Has any one had any experience with Meguiars Paint Reconditioning Cream D151. I see a lot of people talk about it. Was looking for a good one step solution to save time. Any thoughts?
Does Menz Power Finish have more cut than D151?
I have spent a bit of time using this product and don't get any quality results to speak of. I guess I'll try again. It is full of stuff that fills either on purpose or by accident, so the results seem to be short lived at best.
Thanks for the write up.
Cheers,
I agree. Lots of downward pressure for one complete cycle, add a drop bit more PRC, then one or two passes at normal pressure to final polish. Done.
It's definitely on purpose. This stuff is designed to be worked hard and fast as a quick one-step. Like I mentioned earlier...
That doesn't mean we can't modify application technique to better suit our style of paint correction.
It seems to react well to how I've been using it, anyway.... :buffing:
Here's my latest experience with 151, and why I'm not all that happy with it...
I was doing a black Acura last week. After doing a test section on the trunk, I determined that M105 with PFW, and UF X2 with red foam would give me excellent correction and a flawless finish. Do to an unexpected time constraint, I decided to follow the 105 with 151 on a red pad, and call it done. I didn't have enough time to do UF X2, then an LSP.
After doing the entire car with 105 and PFW, I was left with a very lightly hologramed finish. That's to be expected on such soft paint. However, after doing the entire car with M151 on a red pad, using it pretty much as described by iamwaxman, the car looked far worse that it did after the 105. I was shocked, and needless to say, not very happy. I wish I would have had more time to experiment with the 151 on that particular paint. I just can't imagine how I could have finished it down any finer than I did. That guy will be returning for a free full exterior detail.
Edit: The red foam pad is Edge's wave foam. Zero bite.
It's been made very clear to clean the pad frequently with the Meg's MF system, and now D151. Does this go for ALL polishes/compounds? I would think so...
anyone else find that if you use a air compressor to clean the mf pads they get really clean/dry and you have to prime the pad again?
