fancyfootwork
- Feb 19, 2010
- 817
Megs makes some excellent products. Ultimate quik wax rocks. Great smell too it. Ultimate compound is good but I prefer Menzerna or 105 because of the better cut. I also really dig Megs glass cleaner.
Thanks for it, I am now convinced it is worth the the money, even with the crappy sprayer.I have so much Ultimate Quick Detailer. I got 3 for around $15 and the sprayers didn't work so I emailed Meguiar's and they sent me 3 more so I got $60 worth of detailer for around $15.
:updated:
I finally decided to give the Meg's UC a try, and did a test spot on ly old Bronco II after wet-sanding with 2000 grit. My goal was to see if the Ultimate Compound could remove 2000 grit scratches. Keep in mind that I did not use a machine for this test:
Since I did this test in direct sunlight, I had a bit of a problem when removing the Ultimate Polish, So I used the Ultimate QD to help remove. I then applied the Ultimate liguid wax to seal an area just big enough so there is a noticable difference between the sealed vs. non-sealed polished area.
You will notice a small amount of distortion in the reflection, due to the slight curvature and a dent.
That metal flake really pops now!:dblthumb2:
Really good stuff for OTC.
Loving their QD so far...IMHO probably on of the BEST QD's I have used to date...
I love Ultimate Quik Detailer/Wax. To everyone who loves Ultimate Quik Wax, you guys should get a gallon of the synthetic x-press spray wax... It's a great value for money. I just recently acquired the Ultimate Compound and Polish. I can't wait to try it out and see how it compares to M105/205.
I agree with you Chris. UQD is the only QD type of product I use. I only use it as a drying agent though.
