A4 1.8tqm
- Apr 4, 2009
- 1,932
I got a good deal on a nearly full tub of P21s 100% from Christian900se, he has too many paste wax's and this was just sitting unused. Thanks Christian!
Wax came with everything as if it was new and lightning speed shipping!
I waxed the trunk of a friends car for a test spot (it needed wax as we've been sanding out orange peel panel by panel and just finished the trunk. Sorry no pics). The wax goes on thin, quickly passes the swipe test, buffs off with ease and looked great. All as expected.
But when I pulled the wax from the jar I found that it was crumbling at the bottom. It didn't piss me off even a little because I immediately knew what was about to happen, MELT AND RE-POUR! I've read a few posts about melting and mixing wax's and have wanted to try it myself. A great opportunity as I haven't been able to bring myself to dig into a jar of perfectly fine wax.
I loosened up all the wax from the bottom of the tub and shaved any pieces off of the solid chunk.
Then added all the wax pieces to a clean glass jar.
I heated some water, to almost boiling, in an old camping pot, this things seen it's share of camp fires.
Placed the jar into the water for a make-shift double-boiler
Didn't take too long to start melting
Stirring
More melting
Completely melted
I poured the melted wax into my clean and empty tub of Original Formula P21s
Poured
I left it overnight to harden, the wax has returned to the consistency I would expect. It's back to a solid paste, smooth to the touch and when you swirl your finger on the wax surface it slightly melts under your finger.
I'm glad that it returned to normal. Now I just have to do a 50/50 test of melted and re-poured vs unaltered. If the tests prove no ill effects, I may have some interesting and entertaining posts in the future*.
*I just like to experiment, I'm not thinking that I will create the "next best thing" or some "super wax". The chemists know best.
Stirring
More melting
Completely melted
Poured
