Rsurfer
- Jan 26, 2007
- 14,163
- 26
5.5" pads are best with the pc and 4" pads will give you better correcting ablities.I realize that, but I thought if it would do anything then po85 can work
Perfect for me, thanks! Just the type of info I needed. This and 85/blue should serve me well between major corrections.I've used 85 on a white pad with my flex. It works on minor stuff only.
Hi,
What do you guys think about the new gold LC CCS pad which is for jeweling using with the 85rd or should I stick with the blue pad?
There won't be a whole lot of difference between the two, neither one really has any cut but the gold is a little softer. I would say use the gold one on only the softest paints.
I have the Mernz PO106FF and PO83 that Ive yet to try...would the 83 be close enough to this 85RD if used with the 106ff...???
Menzerna's Power Finish is a great product too, it basically does three in one, mild cutting ability ( just under SIP) polishes and shines like a NanoYou really dont want to be correcting anything with 85rd. Its best used as a jeweling polish to increase gloss. If you need something stronger Id step up to 106FF.
Like my Dad use to say, "Do it right the first time"I would agree its a great polish but does need to be followed up.
can you use 85rd with the flat black lc pads? I do not have any blue.
