Menzerna equivalent of Meguiars Fine Cut/Swirl Remover
mkuzmukerau
What products in the Menzerna line are equivalent in cutting ability to Meguiars Fine Cut Cleaner and Swirl Remover 2.0. Anyone have experience with both these products use the Menzerna line? How are they alike/different or better/worse?
Thanks
Mike
I've used the Megs fine cut and found it to be rather mild.
The Menz Nano Polish (106ff) is superb for finishing.
Thanks
Mike
Meguiar's products don't even come close to Menzerna. Menzerna is superb, Meguiar's is just "allright".
Yep, Fine Cut is pretty mild. It has less bite than DACP. I guess it would be somewhere between 106ff and IP in the Menzerna line.
I used to use the Meguiar's Fine cut and Swirl Remover before I found the Menzerna line. The Intensive polish is has more cut and finishes off nicer than the Meguiar's Fine. The Nano and Final Finish are much better than the swirl remover
I would suggest Micro or Finish Polish as closest equivalents personally.
