Using a Griots Garage 6" DA buffer and 5.5" Lake County Hydro-tech pads. Detailing a 2012 Chevy Cruze in Crystal Red Tintcoat (leased - do they apply some kind of sealant or coating on top of the clear coat for leases? just curious)
Method:
-Cyan with FG400, Tangerine with SF4000.
-Applying between 9-15 lbs of pressure on speed 4.5 for everything.
-Doing 4-6 section passes for both compounding and polishing.
-Paint is clayed and free of contaminants.
From what I can tell, this clearcoat is pretty hard. Definitely harder than my 2007 Acura TL type-S's black pearl. I'm running into major dusting problems which I thought were less of a concern with this product as compared to the M105/M205 combo that I am accustomed to using. The working time seems to be significantly less than what I am used to as well. My pads are also pretty warm once I finish a section pass.
Any critique or recommendations that you guys have based on what I have told you I am using between my GG, products, and method?
I did the hood tonight and the results came out pretty good as far as I can tell. Here's some money shots. It's very difficult to see defects in this paint for some reason.
Method:
