How do you apply this stuff sorry for a noob question. how good are the concealing capabilities? I have already done Menz IP and FPII just wanted to hit it with a glaze before throwing on some WGS3.0
I would say the concealing abilities of the glaze are very minimal in the test I did. It does provide a deep wet look on black, but I didn't really see much in concealing going on.
Also it felt to leave a bit of a oily residue even after removal and topping with DGPS.
I have used this glaze a few times..and found its best to use by hand more so than by machine if you want to conceal light swirls..
also I found that a wax works better with it than a sealant...a sealant can be used ..but it seems like the durabilty takes a hit ..example..say a sealant usally lasts 3-4 months with out the glaze..well it will go 2-3 months maybe...
also i found that using a wax like Megs 16 or collinite..very durable waxes last as long as a durable sealant or longer over the glaze since they are not crosslinking specific products like a sealant requiring a clean oil free surface for best results....
its a nice glaze....apply it thin to a section and then remove ..do a section at a time if doing by hand..the results are very nice...top with a wax for best results....lasts longer
