Menzerna Intensive Polish PO 91 E
Irishwoodchuck
So I just ordered Menzerna Intensive Polish PO 91 E into kit and want to make sure I have the process right. I will be working by hand not machine. I clayed the car about 2 weeks ago so it should be pretty clean.
Process:
Wash/Dry Shampoo(poorboys)
Polish Menzerna Intensive Polish PO 91 E
32 oz. Menzerna Final Polish PO 85U
Seal (DP Poli Seal)Detailer's Pro Series DP Poli-Coat Paint Sealant, polymer paint sealant, auto paint sealant, DP Policoat paint sealant, paint sealer
Meguires 26 cabana wax 2 coats
Any suggestions would be welcomeFeed back please
Ben
Process:
Ben
Are you buying these polishes from AG? They are pretty old numbers.
I do own a Black and Decker 6" waxer/ polisher but I havent used it on this car i would need to replace the bonnet if I went that way. I know a lot of guys machine polish but I just dont have the money.
That B & D is only good for waxing.
Yeah that s why i strayed away from it and its getting older too
It's still better than doing it by hand, Wally World has 6" pads for that last itme I looked.
Are those pads or bonnets? The B & D polisher uses bonnets and imo doesn't have enough power to break down any compound/polishes.
Is it better to do the poli seal after the polish?
Skip the opti seal and do two coats of wax?
Do the poli seal them do the polishing?
I've been reading about stickiness?
Poli Seal if I remember correctly is an all in one. It has very light correction ability.
You should have bought some 8oz bottles of Optimum Polish or some OTC Meg's Polish. Almost would have saved enough to get a DA.
I wish I could just do it correctly for you. Polishing by hand is going to be a mission my friend...
Ill just take my time and go slow, yes the black and decker takes bonnits. Im also not going to to overload on polish maybe a dime size rather than a nickel since I will be doing it by hand and have read about the stickiness that occurs with over use.
I might pick up a PC on Black Friday in the mean time should I hold off on polishing it? The directions say it can still be done by hand?
Thoughts?
