Menzerna/ Megs DA MF Discs
silverfox
I'm curious...has anyone tried these products together, and if so, what combination of Menzerna polish/ MF disc did you try, and what kinds of results did you get. Toying with the idea.
I've used SIP and 106FA with the cutting pads, and 85RD with a finishing pad. All worked very nicely.
PO85RD with a MF finishing disc... is one option I'm really anxious to try. Thanks for the input. I'm assuming you worked it at the "slower" DA polisher setting of "3"..?..
i tried IP with a finishing disc ( i know its a not a final polish) and it followed up after 105 pretty good. still some very light light hazing....but not bad. it started to rain so the next day i just put on power lock and ill finish it at some point
Worked it at 4 for 2-3 passes, then dropped the speed for another pass or two.
