I've used various compounds like pinnacle etc with a blue cyan and it's not enough.
There's a compound in Pinnacle and two polishes. The compound is as aggressive as any quality compound on the market.
To get more aggressive you need,
More aggressive pad
More powerful tool.
More goal is to find the easiest way to get there And not have to work myself to death
I have numerous articles on this forum where I buff out trashed cars in under 6 hours using the FLEX 3401.
Another option is to start with a rotary and finish with your Porter Cable to avoid holograms.
Another option is to get the GREY THINPRO pad and trudge through the compounding step with your PC.
I taught a couple of newbies how to machine polish on an expensive paint job with water spot etchings. They wanted to use safe tools like the PC. So I amped up the PCs ability by added the grey ThinPro pads.
Click the link, look at the before pictures, read the text and then look at the after pictures.
1955 Chevy Bel Air with a $15,000.00 Custom Paint Job - How to remove water spots
Here's an excerpt...
Test Spot 3: We switched over to the
5.5 inch ThinPro Gray Extreme Cutting Pad while sticking with the McKee's 37 Fast Compound. This did the trick. The thinner, much more aggressive foam cutting pad with the McKee's 37 Fast Compound completely removed the water spot etchings with the normal 8 section passes.
Car came out pretty good...
Notice most of the guys in the background are using the FLEX 3401 with LC Orange Hybrid pads, (cutting pads), more power, faster results. The FLEX 3401 aka
the BEAST!
