Menzerna Power Finish PO 203 now at Autogeek
I just tried it on a 2 year Toyota Tundra that sits outside 7x24 and was waxed (2 years ago). I did a white LC pad via Flex and it worked really well. Took out the crud and oxidation plus any swirls - finished perfectly. Not bad when you factor in I worked on it in temps that were only in the low 50's, despite my propane heater! I used a little QD on the pad too, seemed to help spread it and work it - there again, it was chilly in the garage.
Hi
i am using same sort of product suggested by my friend who is working in a prominent car shop 'autotropolis'. The frequent stake pertaining with such product is deterioration of the original color of car. so, i am bit scare about using this product. But, i will definitely sugest my friend if he would wish to try something new.
Thanks
"Deterioration of the original color of car" ??????? Not sure what that is about? It didn't take my customers paint off ??????????
Sounds like Brighto - if anybody remembers where that came from, hint - used by those masters of mayhem, Moe, Larry and Curly!
Hi
Thanks
You're very new to this industry I take it, and that's not a bad thing, the search feature should be your guide.
