Menzerna Update
Meghan
Super Moderator
A lot of you have emailed and called about the two Menzerna products we were waiting on to come back to stock. Well they are off backorder on the site and available to purchase. We will have them in the warehouse on Wednesday, so they will ship out to you ASAP.
So you can go ahead and order and we will promptly take care of you on Wednesday.
Thanks!
Thanks!
Are you talking about me?
What products are we talking about here?
Final Polish and Super Intensive
I would like to see PO 73 in stock, can you guys get that or no?
:cheers:
:cheers:
I will check into to it for you!
What is the difference between the APO 60 and PO73...
Menzerna PO73 Sealing Wax cleans, glazes and seals the paint.
Containing a mix of Carnauba, Glycerin and Aluminium oxide, we belive Menzerna have cracked it again with a product worthy of topping their polishes. Use this after polishing to add some life back into the paint. The gentle aluminium oxide cleans and removes any compounding dust, whilst the glycerin glazes the paint. The added carnauba in this product then adds some depth and protection.
sounds the same as APO 60....
Al
Al
Only difference I understand is the cleaner. And we have requested it.
Ok ...maybe PO73 is more abrasive..?...cause APO60 is a 1 cut on the scale...so it does have abrasive cutting power...which in turn will clean...
Just curious....I have never seen the offering before ..just the APO60...
AL
Al
PO 73 has a cut of 0. APO 60 has a cut of 1 and has cleaning ability
I do not want any cleaning for a LSP as I just found a technique
to apply the glaze ;)
:cheers:
Menzerna Polishes
:cheers:
OK..I seen the aluminum oxide was in PO73 and it thru me off...aluminum oxide is a abrasive...but they may have it powdered real fine ....I seen it has no cut on the chart I have....after I looked at it...
AL
i noticed each polish list upto what sanding grit it is capable of removing..
how do you determine how fine or severe the scrathes are by sanding grit
Example: 1500,2000,2500 etc...
