Metal/ Aluminum Polish
lunchboxmunchy
Hey Geeks. I have used Mother's Aluminum Polish and have been pleased with the results. However, it there is minor pitting, scratching or really "stubborn" areas, it doesn't work well. What other kind of bare metal polishes are there that'll work well. I don't have the option of removing the rims and whatnot. Mainly, motorcycle rims.
Feed back please
I have been using NuVite for 10 years now for all my aluminum needs. Love their stuff.
PMing you man - dont think I can post a link to it.
They have extremely aggressive to final polishes ..... just like with clears/paints when its real bad you must do it in steps - no real miracle one step just yet :buffing:
Can you send me that link too please
Sent from my SCH-I535 using AG Online
For over the counter, I've had great results with white diamond metal polish and sealant. I have probably 6 different metal polishes and it's the best on my high polished aluminum wheels.
For bare aluminum Gord's Metal Polish or Zephyr. For final polishing white diamond or the mothers brand you displayed (OP) or anything that is white in color.
If it is defect removal you are after than you must use appropriate buffs and rotory buffers. It is very hard and time consuming to remove defects by hand.
Here is a time tested trick, if you have black tag left in the pitting or scratched areas, rub corn starch or white flour into the metal with a soft cotton cloth and the black with disappear without scratching the surface. Then seal with your favorite brand.
My new metal polish is Meg's motorcycle all metal polish stuff is great $8.
I'll second the flour or cornstarch trick. That's what's in the bucket with the yellow lid in this photo. Whenever there's lots of aluminum, my flour bucket is there somewhere.
Kevin/Dave...
Thanx for the tip on using corn starch and flour!
Bill
Didn t know about these tips , thanx fella ! Learn everyday right !
I'd love to see a write up using cotton wheels, the grease-less compounds, and rouge to restore aluminum wheels or something else.
Don
Don
There's some YouTube videos out there. But I would like to see some too!
I have seen videos on YouTube, but they don't give me what I want to see. I have a feeling Autogeek won't use the cotton wheels, grease less compounds, and rouge because they don't sell that stuff. I would love to see a rough aluminum to mirror finish using a rotary.
...but they don't give me what I want to see.
What part of the transformation is lacking on these video demonstrations?
What issue would you like to see addressed? On which type part, e.g wheel, panel, trim, heads ?
Just like in polishing paint.... Prep is key to polishing aluminum to a mirror. Depending on the grade/ condition of aluminum you are starting with..... You would sand with a d/a sander . If the aluminum is pretty rough... Start with 220, then 320, 400, 600. You must make sure you sand out all the previous grits scratches... If you don't, you will see them when you start polishing. Then you will have to go back to sanding all over to remove those missed scratches. If done right... After 600, you will have a reflection, although a very hazy one. From there, you can keep sanding with 800, 1000, 1200. But those aren't necessary if using rouges with buffing wheels or "airways".
If using airways, you need special safety flanges to help keep the metal center that mounts to the buffer from separating and flying apart. I could walk you through what rouges and wheels to use, but they don't sell them here and don't know what the policy is. But... I must warn you... You could talk to 5 different polishers and get five different ways to polish and what products to use.
I know this probably CAN'T exist because we're talking totally different chemistry makeup between two materials... but I just wish there was ONE polish for metals, period - ha! Mag, chrome, steel, you name it.
But, in detailing, specificity is better I know!
Tried the corn starch yesterday...YAHOO! It works 'as advertised'!
Thanz again!!!!
Bill
