MF bonnet set
mesmeral
Quick question here. Can the W64 meguiars rotary backing plate, 6 inch lambswool leveling pad and 6 inch microfiber bonnet be a good fit for each other?
Read that the leveling pad and MF bonnet will work with a 5 inch backing plate.
It will work, but I would be reluctant to use it on a rotary.
Hi rsurfer,
Can you advise why? Still kind of new to this.
Hi rsurfer,
You are spinning a mf pad at high speed and it can get hot quickly being that you are removing dried wax/sealant. End results could be burnt paint. Yes, you could use lower speeds (600 rpm), but your mf bonnet will still load up quickly. IMO it's just a PITA and not worth the effort..just use a good quality mf towel.
