MF pads on 3401
Bicycle
Member
I want to try MF pads on my Flex. In Mikes book on the Flex he recommends the LC rotary pads because of the extra thickness.
What's other MF pads are good on the Flex.
Thanks.
I have tried a few different brands of MF pads on the 3401 and personally do not care for the way they feel while buffing. Too grabby IME.
I have tried the Lake Country MF pads, Meguiar's MF pads, and Optimum MF pads. If I had to choose one that returned the best results for a MF pads it would have to be the Optimum pads. I was also using FG400 and M105 as my compound.
However I would much rather use wool pads on the 3401 as they offer more cut and better better feedback. Besides, a wool pad will out cut a MF pad with the forced rotation of the Flex.
Thanks Mike. I'm gonna try the LC purple wool foam pads.
A couple of questions. During the buffing process, would you clean these with a brush or compressed air. And four a full size truck would 4 pads be enough??
Thanks again.
Thanks again.
Use compressed air to clean the pads if you have it. I'd go 8 pads...
I use Meguiars MF cutting and polishing pads on my Flex with no problem. I never really need to go above speed 4.5 with them. The foamed wool pads are also perfect for the Flex.
