slickooz
- Nov 8, 2010
- 2,657
So today I got a chance to test out the cutting pad and compound from MF system. I helped a friend compound/polish/wax the hood. When the car arrived I already knew that the paint was bad condition because he brings it to a automatic car wash a lot.
So I started with ONR wash on the hood. Then clayed it with DP clay bar with DP waterless wash as spray detailer. Then pulled the car into the sun to see what I'm up against.
Here are a couple 50/50 shots.
The MF cutting pad/compound is really aggressive and left the Subaru paint very dull. I opted for M205/white pad because I wanted to apply AutoGlym HD as LSP. On soft paint, using MF cutting pad/compound you have to do another step because it just too aggressive and marrs the paint.
I could see how this can replace yellow/orange pad with M105. It dust a lot less and easier to wipe off. The correction is great but the pads needs to be cleaned after every section because it products build up fast. Cleaner pads equals more corrections.
I got to use Eraser for the first time and wasn't really impressed with it. Went to finish the rest of the hood with IPA and it took everything off. Gave it a clean surface to apply LSP.
I went with AutoGlym as LSP and it does an AMAZING job beading water off paint. Out of all my wax/sealant, I think it's hands down, beads the most. Here a short video of beading in action.
[video=youtube_share;6y-QddtHgI8&feature=channel"]BEAD! - YouTube[/video]
