Microfiber 101 with DFB
DFB
One of the biggest advancements in the detailing world over the last 10 to 15 years has been the massive increase in the towels we use to clean our cars. With so many microfiber towels on the market from a variety of different brands, it can be hard to know what to start, then what to buy.
Knowing which towel to choose for each detailing task is something that takes time to perfect. Choosing a weave type and GSM to suit each task will save you time and improve the finished result. This thread is aimed at those looking to have the right towel for each and every detailing job, allowing you to skip the trial-and-error stage.
But first, let’s look at the basics, an important factor when choosing towels.
Microfiber 101
What is GSM?
Grams Per Square Meter. This relates to weight or density of the towel fibers, not necessarily the thickness or plushness.
What is the blend?
The blend refers to the ratio of Polyester and Polyamide for each towel. The Polyester provides the cleaning ability, the Polyamide provides softness and absorbency.
What is the weave?
This describes the length (pile) and shape of each individual fiber (weave). Again, different detailing tasks require different pile/weave designs.
Weave types include –
Plush Pile –
These towels have long fibers on both sides, providing a cushion between the towel and the surface by reducing the pressure points of your hand.
Pro’s – Plush towels are usually softest feeling of the bunch and are best for delicate surfaces, like soft paint or piano-black gloss trims.
Con’s – In some cases, the long soft fibers don’t provide sufficient “bite” for cleaning duties. These towels are not always ideal for drying as the fibers can create excessive friction and drag when wet.
Dual Pile –
As the name suggests, these towels have a low pile on one side and high pile on the other.
Pro’s – Versatile, these towels strike a balance between cleaning ability and softness for delicate surfaces. The plusher side is ideal for spray sealants and polish removal on softer paints. The shorter side suited to heavy compound removal or interior cleaning.
Con’s – Jack of all trades, master of none?
Twist Loop / Twist Pile –
These towels have loops of fiber that are bundled and twisted in a double helix pattern. A twist pile weave increases the surface area of the material, which in turn improves absorbency and smoothness when wet.
Pro’s – High absorbency and reduced friction when wet makes these ideally suited for drying. They are great for glass too due to the density.
Con’s – Grabby when dry and expensive to make/purchase.
Closed-loop / Pearl-Weave –
Pearl weave towels have a tight weave and a low closed-loop pile.
Pro’s - The low pile makes these great for biting through compound, polish and wax removal. They are also an effective coating removal towel, and can be used for glass cleaning. Softer than Twist Loop.
Con’s – While soft feeling, closed-loop towels tend to be more aggressive than their plush counterparts. More expensive.
Waffle Weave –
Waffle-weave is the original car drying microfiber towel. With no pile, they have a crosshatch pattern of low and high sections, the ridges creating a squeegee effect across the surface. Despite the lack of pile, they are super absorbent.
Pro’s – The waffle weave pattern helps reduce contact with the surface, in effect making it glide with less friction. Ideal for drying or glass cleaning duties. Low/no linting.
Con’s – Not the best for softer paints. More expensive to make/buy.
Hybrid Weave –
As the name suggests, these towels combine two different weave types to create a best of both worlds. For example, the TRC Gauntlet combines the high water absorption of a twist-loop towel with the smoothness and lack of grabbiness of a plush weave towel. Or the TRC Platinum Pluffle, which combines the softness of a plush weave with the absorbency of a waffle weave.
Pro's - High water absorption and smoothness across the paint.
Con's - Expensive to make/buy.
Diamond Weave –
Specifically designed for glass, a diamond pattern towel mimics a waffle weave in having reduced surface area for a smoother, less grabby feel.
Pro’s – Reduced drag and easier wiping across glass. They can also be great on polished metals. Low/no linting.
Con’s – Limited use, lack of versatility.
Terry Weave –
The most common and most versatile type of microfiber, terry weave towels are also what most think of when the word “microfiber” is mentioned. Not to be confused with cotton terry towels (remember those?), terry weave towels have open ended fibers that are bundled in small groups. With so many “fingers”, it makes them ideal for cleaning duties. The most common and most identifiable type of microfiber, terry weave are generally low pile towels.
Pro’s – Terry weave towels are cost effective and decently absorbent. They are great for interior cleaning, exterior dirty jobs, metal polishing, coating removal, polish and wax removal. Low linting.
Con’s – Can sometimes mean a cheap and nasty towel, choose wisely.
Suede –
An ultra-low pile with a completely smooth and soft feel, suede towels have minimal use in detailing.
Pro’s – The short pile makes them lint free and ideally suited for cleaning instrument clusters and screens or used to apply ceramic coatings.
Con’s – Limited use.
Chenille –
Some like these, some don’t. Chenille is generally used in wash mitts and pads and are recognized by the bundles of microfiber “fingers”. With so many “fingers”, these have a high surface area to improve cleaning efficiency.
Pro’s – Ideally suited to exterior washing of bodywork and wheels. The material used in these wash mitts is highly suited to being fully wet.
Con’s – Some suggestion that they are not as safe as other types of wash media.
To be continued.......................................
Pairing Towels to Specific Tasks
It’s taken me years to arrive at the following list. It’s worth noting that towels can be very subjective and personal, so use this listing as guide to get you started or what to look for.
Most of my towels are from The Rag Company (TRC), with a couple from Microfiber Madness. You will notice some duplication here, with colour used to differentiate towels into usages. Where I have specified a colour, this has been done to provide differentiation where the same towel serves dual roles. I probably have a lot of unnecessary categories here, so pick and choose those that are relevant to your needs.
Wash Media (Mitts, Pads) –
Personally, I hate wash mitts and much prefer a wash pad, but I know that is subjective. After trying many different formats and brands, these are what I have settled on –
DFB’ Pick – TRC Cyclone Ultra
Any of the TRC wash mitts and pads are great, but the Ultra line is their softest and safest of the bunch. These are available in four different formats; mini-mitt (wheels), regular mitt, regular pad and the 10x extra-large pad. Personally, I use the regular size pad on passenger vehicles, the 10x for larger SUV’s and pickups. The wheel mitt is excellent too.
DFB’s Wildcard – Microfiber Madness Deli-Pad/Mitt
Available in mitt or pad, this is an excellent option for softer, more delicate paint. The Deli-Pad and Mitt are thinner than expected, but much plusher and softer feeling.
DFB’s Suggested Quantity – At least one per vehicle.
Drying Towels (Large) –
This is probably one of the most subjective towel categories. Some prefer the lack of bulk and extreme absorbency of a twist-loop, some like that ultra soft padded feel of a plush towel, some favour the smoothness of a waffle weave. For me, the ideal drying towel combines all of those attributes.
DFB’s Pick – TRC Gauntlet
Available in several sizes, I prefer the medium as it’s more than big enough for most vehicles without becoming a bulky pain in the neck. I like these towels because they combine the absorbance of a twist-loop towel, but the softness and smoothness across the paint of waffle weave and plush towels. 700 GSM and a 70/30 blend made in Korea.
DFB’s Wildcard – Waxit Tempest
Considering my dislike of twist-loop, I had to think back to what I was using pre-Gauntlet, the Tempest was that towel. These are a ultra plush 1000 gsm towel that are thicker than most modern towels, but the feel is plushness gives an impression of safeness. I would say stick with the Jr. version as the large is very bulky. An alternative to this would be the Bowden’s Big Green Sucker or Drop Bear.
Drying Aid Towels (Small) –
When using a blower of some kind to remove the bulk of the water, you really don’t need a big drying towel to finish the job. In this instance, I prefer a smaller square shaped towel, 40cm x 40cm in particular.
DFB’s Pick - Microfiber Madness Chipmunk Jr.
This is a towel TRC don’t currently make, as in a 40x40 version of the amazing hybrid weave Gauntlet. Enter Microfiber Madness! I landed on this towel after trying a variety of potential candidates, most disappointing for drying aid use. This towel has just the right combination of bulk, plushness and water absorbency.
DFB’s Wildcard – TRC FTW
While I have a number of these for drying aid duty, I find the twist-loop FTW a touch grabby for my liking. That opinion is subjective, some really like them for this role. Worth a look, just know it will be on the grabbier side.
DFB’s Suggested Quantity – At least 4, or two per vehicle.
Wheel Towel -
Probably a useless addition, especially if you are blow drying, but I still like to give wheels a final wipe down after dressing the tyres. Because of the closeness to the floor, I think you need a smaller than average towel to avoid dragging it across the ground.
DFB’s Pick – TRC Gauntlet (30cm x 30cm)
I know this is probably too nice of a towel to subject to this task, but me, this is one of those towels that suits its job so well. It’s perfectly sized and perfectly weighted to work between the wheel spokes without excessive bulk or change of dragging on the ground or on the tyre. One of my favorite towels.
DFB’s Wildcard – TRC Creature Edgeless (Black)
This is a hard choice because of how transcendent the Gauntlet is at this task. I settled on the Creature because of its 420 GSM, dual-pile versatility, size and relative cost effectiveness. You could also do the Spectrum, which is a edged version of the Creature, but the edgeless is easier to manage.
DFB’s Suggested Quantity – At least 2, or 2 per vehicle.
Door Jamb Drying –
I know, I know, another category, but one I personally believe in. Depending on how dirty these are on your vehicle, you can probably get away with using your normal drying aid or large drying towel. But for dirtier applications, I tend to favour a separate waffle weave towel.
DFB’s Pick – TRC Dry Me A River (Light Blue)
I have these in the 40cm x 60cm and 50cm x 100cm sizes to cover different vehicle sizes. Even the small 40cm x 40cm would be great too. The lack of bulk with these towels makes them ideal for getting into these space restricted areas.
DFB’s Wildcard – TRC Platinum Pluffle 40cm x 40cm
This towel is perfectly sized and incredibly soft, perfect for well-maintained cars or softer paints. Get them while you can, this towel is soon to be discontinued.
DFB’s Suggested Quantity – At least 2 per vehicle.
Glass Towels –
For glass, you need a dense, low pile towel to limit streaking and linting. There are a variety of glass-specific towels, but I’ve settled on waffle weave.
TRC make a variety of waffle weave towels, but their premium DMAR is the best for glass. In particular, you want the 16x24 version. I’ve found these to be the smoothest and easiest towel to clean glass.
While I listed this towel as a drying aid towel, it was originally designed for glass, FTW means “for the windows” or “for the win”. The lower pile and high density makes them a great choice for glass.
DFB’s Suggested Quantity – At least 4, two per vehicle. If you have really nasty interior glass, you will burn through more towels as each becomes loaded with grime, so you may need up to 6.
Coating Removal Towels –
This category is probably the most complex when it comes to choosing the right towel. As a rule of thumb, for coating removal you want a low pile and around 300 GSM to help cut through that initial residue and prevent pushing product around. When leveling, you use two towels, one for the initial wipe, a second for a final buff. To help with this, I like to have the same towel in two different colours, that way you easily remember which is which.
There are two ways to look at this. Considering these towels are best thrown into the rag pile after use, the dried coating will ruin your hard work in seconds if used on paint again, investing in expensive towels here is a fool’s game. On the other hand, using a cheap towel could compromise the finish you have spent hours perfecting. Which route you chose would depend on the paint you are dealing with. For soft Japanese paint, I would spend the extra on a pearl weave towel. For medium to hard paints, wheels, glass and trim, a cheaper terry weave towel will be just fine.
DFB’s Pick (Soft Paint) – TRC Edgeless Pearl
These are a 320-gsm pearl weave towel that are extremely efficient at coating removal. They are also available in grey, orange and green to help you colour-code their first/second wipe statis.
DFB’s Pick (Medium-Hard Paint) – TRC Edgeless 300
As the name suggests, this is a 300 GSM towel that balances a cost vs performance equation. These can be had for about $3.00 each compared to the $5.50 for the Edgeless Pearl.
DFB’s Wildcard – TRC Ultra Rip’n’Rag XL
These towels come in a roll of 50 for $99.95, which works out to be just on $2.00 a towel. That low cost doesn’t mean low quality because these are a pearl weave towel with 280 GSM and a 70/30 blend. In actual fact, this is probably the best balance between the two towels above.
DFB’s Suggested Quantity – At least 4 to 6 per vehicle depending on the coating and surface area treated. I would order a 10 or 12 pack of the Edgeless 300 or Edgeless Pearl for bulk price rates.
Wax/Sealant/Polish Removal Towels –
It took me a long time to figure this one out, but for polish and wax removal, a low pile towel is much more effective here. That can be hard deal with if you have soft paint, so my choices below mimic the coating removal category. Having sufficient quantity of these towels is important, a fresh, clean towel will be more efficient, so this allows you to swap them out more often.
DFB’s Pick (Medium-Hard Paint) – TRC Edgeless 365
As the name suggests, this is a 365 GSM, 70/30 blend towel. These terry-weave towels deliver a nice balance between a low pile without sacrificing quality.
DFB’s Pick (Soft Paint) – TRC Eagle Edgeless 350
Despite the lower 350 GSM rating, this plush towel is better suited to soft paint. The Eagle 350 is better suited to polish removal than the thicker Eagle Edgeless 500.
DFB’s Wildcard – TRC Creature Edgeless (Grey)
As a dual-pile towel, the Creature is basically two towels in one. In theory, having a set of these would negate the need for two separate towels to cater for soft and hard paint. At 420 GSM, they share the same 40cm x 40cm size of the two above.
DFB’s Suggested Quantity – At least 10, probably 15.
Interior Cleaning Towels –
In most cases, you want a lower pile terry-weave towel for interior cleaning purposes as they will better deal with cutting through grime. I also think you want a slightly larger rectangular towel here, especially when cleaning larger areas such as leather.
DFB’s Pick – TRC Car Wash Towel (Green)
These 80/20 320 GSM towels have been my go-to interiors for years now, they are perfectly sized at 41cm x 69cm and are also extremely durable. I’m using these to clean leather and plastics, wipe screens and instrument clusters, cleaning fabric and general wipe downs/dusting. Cost effective too.
DFB’s Wildcard – TRC Creature Edgeless (Green)
Another appearance of this towel, the plusher pile and higher 420 GSM makes it better suited for delicate surfaces such as piano-black gloss trims.
DFB’s Suggested Quantity – At least 10.
Rinse-less Washing Towels –
There are a few different ways to go about rinse-less washing, but I prefer the multiple towel or “Garry Dean Method”. For this role, you want a 40x40 square shape, which allows you to fold the towel to create eight different sides, which you flip and fold as each section becomes dirty. I also think you want plushness for this job, hence the two listed below.
DFB’s Pick – TRC Eagle Edgeless 500
This is one of the softest towels you will experience. Although they get a little heavy when saturated with rinse-less, they do provide less pressure points when guided by your hand. I also like the edgeless construction as it means you get the same surface no matter what section of the towel you use.
These hybrid-weave towels were my original choice for rinse-less, and its certainly still a great option. The waffle weave element of these hybrid towels adds an extra layer of safety when rinse-less washing. Act fast, these towels have recently been discontinued.
DFB’s Suggested Quantity – You will burn through these per vehicle. On a Falcon sedan or Mustang sized vehicle, I would use about 5 to 6 towels. So, I’d probably make that 12 or 6 per vehicle.
Beater / General Purpose / Dirty Job / Engine Bay Towel -
This is a towel you are going to hammer, so it needs to strike a blend between cost effectiveness while still being effective. One could say that a pack of basic towels from the hardware store or cheap shop would suit this role, but trust me here, I have done this in the past and they just never do the job well………. at all! In that I mean they are hydrophobic and end up working against you.
DFB’s Pick – TRC Car Wash Towel (Grey and Red)
I love this towel, its so versatile, so durable, big but not too big. I have been hammering a set of these for years now and they are still going strong. Yes, some have been sacrificed and replaced, but I’m shocked at how well these have done. I’m using this towel in grey for cleaning/dressing rubber floor mats, wiping down benches or dealing with anything dirtier than expected. In red, this is my engine bay towel. At about $4.00 per towel, they are reasonably priced while still delivering a decent 320 GSM.
DFB’s Wildcard – TRC Rip ‘n’ Rag
The concept of a dispenser box of towels has been around for a while, but the TRC offering takes that up a notch. While these can be washed and reused, at 0.65c per towel, they are can be disposed of at low cost. A 70/30 blend in 30cm x 30cm size and 180 GSM, these are great for metal polishing, oil changes, spill control and can be sacrificed in the name of adhesive and tar removal.
DFB’s Suggested Quantity – At least 10 (Car Wash Towel) or a 80-pack (Rip ‘n’ Rag).
Applicators -
Available in multiple sizes and shapes, applicators are used for tyre dressing, polishing, waxing, trim dressing, glass cleaning, leather care and interior dressing. For the most part, these are pretty universal, at the moment I have been using TRC Pearl Applicators, and the Eagle Applicators are great for delicate surfaces.
Ceramic Coating Applicators -
Another subjective category. The original block and suede method is still favored by some, but most use microfiber applicator bricks, me included. Having said that, having some of the suedes on hand can come in handy for intricate areas.
Notes
How do I differentiate what towel does what?
Colour and labelling. Try choosing a colour that you associate a task with and pair towels to that task. For example, using green for interiors, blue for engine bays, black for wheels…......You will find over time grabbing the correct towel for each job will become second nature.
How do I care for microfiber towels?
A quality microfiber specific detergent is highly recommended to clean your towels properly and safely. Using these detergents helps strip away modern automotive products such as Si02 infused sealants, in turn prolonging their useful life.
A more comprehensive guide to microfiber care will follow.
Microfiber Care
Caring for your microfiber towels is a topic or question I come across often, so I thought it would be good to have a dedicated thread for this subject.
Taking care of something that touches your car so often is very important for both the car and the overall longevity of the towels themselves. While I see towels as a consumable, cleaning and storing them correctly will play a part in how long they last as well as how they perform.
Before I go any further, there are some towels that are generally considered single use. Towels used to level a ceramic coating are one such example, and while they can be deep cleaned and re-used, I tend to sideline them to limit the potential for cured coating particles causing damage. Small, low quality towels sold in a “tissue box” style packaging are a handy thing to have on hand, but at less than a $1.00 each, I also treat these as single use.
Microfiber Washing & Storage -
Having said that, what should you do to wash and store your towel inventory properly? The following generally applies to all microfiber towels, no matter their size, shape, weave type or use case. This also applies to microfiber wash mitts, applicators and polishing pads.
- Have a “clean dirty bucket”. This is a separate, clean bucket used to store used towels before washing. In other words, a laundry basket.
-Wash your towels as soon as possible. As in, wash your car, when you are finished, wash your towels.
There is evidence to support the idea that towels used for applying certain products, such as Si02 type ceramic sprays, can cause them to become hydrophobic over time. Washing them straight away mitigates against this.
-Use a specific microfiber detergent. These are generally designed to deep clean your towels, removing product residue more effectively. These can also help revive older towels and prolong their life. These products work can be used to clean used polishing pads as well. At the very least, ensure you are using a liquid laundry detergent WITHOUT fabric softeners and NO bleach. Suitable microfiber specific detergents include –
Micro-Restore
P&S Rags to Riches
Bowden’s Own Microfiber Wash (AUS)
3D Towel Kleen
Poorboys Typhoon
Gyeon Q2M Towel Wash
McKees 37 Microfiber Cleaner/Rejuvenator
Chemical Guys Microfiber Wash
Carpro MFX
-For towels that have been used to clean excessively dirty areas or have been used to apply a dressing of some sort, consider pre-rinsing or soaking them in the sink before running them through the washing machine. Some will even wash these separately to other towels.
-Use cold to warm water. DO NOT use HOT water. Doing so will compromise the fibers.
-I like to air dry towels indoors to prevent contamination. You can also use a dryer on LOW heat.
-Once dry, fold and sort them back into usage categories. I find this is a good time to quickly inspect the towel for any imbedded debris, especially important on towels that touch the paint.
-Storage will come down to your setup and space. I store them in airtight containers that have been separated into usage categories, having them colour coded helps in this regard, ie green for interiors, red for engine bay, black for wheels and so on. Make sure the towels are 100% dry before storing them in sealed containers though. If you have a clean, dust free garage, then storing them in a cabinet or drawer without a container will be fine.
-Even with correct care, towels will still age over time with regular use. Demote and replace these as needed, especially important for towels used on paint.
Trouble Shooting –
-If you are having trouble with linting, there are two causes for this. You have linting towel/s, in which case you will need to track down the culprit and eliminate the offender/s. I have to say, in all the years of using microfiber towels, I have never had to do this.
The other cause can be from using the wrong type of towel for a particular task. This typically relates to using thicker towels on glass, in this case switch to a twist-loop or waffle weave type towel.
-If you have towels that have become less absorbent or have lost their plushness, then I would highly recommend trying Rags to Riches detergent. This has revived some of my older towels in the past, and with continued use, has kept them in rotation for longer. If this fails to revive them, then it’s time to sideline the towel/s for something newer.
-This is not really a trouble shooting point, but just good practice. ALWAYS wash brand new towels before use.
Final Note -
A lot of this will sound like overkill, but most of it is quick, routine steps to ensure you get the best out of your towels and limit the installation “love marks”.
Sooo is this kit worth it? $89
As a way to get started, probably. But for me, I'm so particular in what I like, some of the inclusions there I would question or swap out, meaning I'd rather put together my own package. Of course, some of that is subjective.
Starting from the top to bottom...............................
All Purpose Terry - I'd swap that for the Car Wash Towel, its the same blend but has a higher GSM and a larger size for efficiency. I'd use this as an interior towel, engine bay towel, all-purpose towel. The Car Wash Towel comes in packs of 10, I'd probably order 30 spread over 3 colors.
Edgeless 365 - To me, this is a bit of a double up with the above. Although, it has a 70/30 blend and higher GSM, which would be decent for polish removal or interior towel. Personally, I'd swap this for the Creature or Eagle Edgeless 350.
Microfiber Applicator - Six of these might sound overkill, but I can see the purpose here. I will say, they are not the ultra soft type, so I'd stick with using these for tire dressing and interior dressing/cleaning.
Jersey Bug Scrubber - I really don't see the need for 5 of these, I have two but really only need one.
Eagle Edgeless 500 - I use these as rinse-less towels, so I'd want more than the supplied 4. I also find they push around spray sealants, so their use is quite limited. If you have a lot of high gloss interior surfaces, they would be great for that.
Dry Me A River - These are my go-to glass towels, I've tried others but keep coming back to these. I think you want more than three though, at least six.
FTW - These were originally meant for glass but have been used for drying and drying aid as well. I've tried these for glass, most people love them for this but I don't.
Gauntlet - One of the best drying towels ever, in the perfect size too. I'd personally order four.
Cyclone Ultra Wash Mitt - I hate wash mitts.
Cyclone Ultra Wash Pad - Personally, I'd be ordering another three.
Wait, what? Discontinued? Oh, I see...it's GONE. Oh well, the Gauntlet is similar, isn't it? And besides, I'm sure TRC will be coming out with a new flavor for people to buy instead of the Pluffle. You can't get people to keep buying towels unless you come out with new models.
Thanks for the insight. I don't have a lot of microfiber towels. Just some all purpose ones, 2 glass towels, a medium sized drying towel and some polish towels. I was thinking this might be a good start to my collection.
Easy to collect a crap load of towels when first getting into this because of so many choices that one doesnt know where to start. Nice job on making that easier for said folks. Havent read it all yet but nice article so far.
  • Like
Reactions: DFB
So very true.
I remember early on I was buying microfiber towels from the dollar store and eBay thinking a microfiber towel was a microfiber towel. When you start out, you tend to go for the more is more mentality, as in buying quantity over quality. I learnt the hard way that buying bulk packs for $20 was a complete waste of time and money, those towels just push product around.
From there, you tend to start buying random towels trying to find what you like. I don't know about others, but I like consistency and order, having a random pile of towels did my head in. Then over time, you gradually phase out the stuff you didn't like and stock up on the towels you like.
The problem with the above trial and error is that it soaks up quite a lot of time and money. Now, I've thoroughly enjoyed the discovery process, the thrill of the chase if you will. However, I think most people would rather skip the time and expense, preferring to get started with a good set of towels without stuffing around. That's why I wrote this article, which was originally posted on a few non-detailing related forums, aiming to help the weekender get started with stuffing around or wasting money. I've also come across some who get quite dismissive of microfiber, complaining about linting or other undesirable factors. In most of those cases, the grievance stemmed from using a crappy towel (say an 80/20 or 90/10 blend) or using the wrong towel for a given task (say using a general-purpose microfiber for glass cleaning).
I'd say most members here would have their microfiber collection dialed in. Still, I hope the article has been of some use, if nothing else to confirm what you are using, or maybe discover something new or different.
Yeah, you clean the windshield, examine your work, it's spotless, so you decide to go for a drive and as soon as you turn into the sun, all the lint appears, all over the glass, and if you're unlucky, it's inside and out.
I'm very particular about glass cleaning cloths and mitts.
I am too, but its mainly because I hate dealing with glass.
1st started? MF is my savings account’s Kryptonite….
I’ve recently changed my process for laundering microfiber towels. For the most part, each step remains, but with one key alteration…………………….
- Place used towels in a clean bucket with sealable lid to prevent the products from drying within the fibres while I continue to work.
- Where possible, never leave used towels sitting for more than a few hours, wash them ASAP! I know the temptation is to wait until you have a full load to launder, but you significantly risk ruining your towels by doing this. The sealable bucket helps here as it prevents the products setting up in the fibres.
- Using Rag’s To Riches as the detergent, I run towels through the washing using the lowest heated setting. If they are excessively dirty, I will use an the “intensive” or extended cycle. The heated water is something I’ve been doing for a while now, which in theory helps purge grime from the towels better.
- Air dry towels indoors, then fold and store in airtight containers, inspecting each as you go for foreign material not removed from the wash (this can happen to the best of us).
For the longest time, I have air-dried towels indoors. Excessive heat can damage (read: melt) the fibres, while indoor drying helps prevent contamination from dust and debris carried by the wind.
However, on several occasions now, I’ve noted comments saying that running towels through the dryer will produce softer towels with less chance of linting. I’d previously dismissed the use of a dryer due to always being of the belief that heat was an enemy to microfiber. But in the last month or so, I’ve switched to using the dryer. And WOW, what a difference!!
To clarify, you should NOT be putting microfiber towels into a dryer and running the machine on the highest setting. You WILL ruin your towels by doing that. Instead, choose the lowest heat setting and run them over a longer period. Also, clean the lint trap before starting. Regardless of material, you should be doing that every time you use a dryer anyway, but on microfiber, its especially important.
The combination of warmth and airflow helps fluff the fibres and draws any potential lint into the trap. The result is a considerably smoother, softer towel. This is especially noticeable on plusher towels such as the Eagle Edgeless, Bowden’s BGS, Gauntlet and wash media. Below are two plush 500 gsm Eagle Edgeless towels. The one of the left was air dried, the one of the right went through the dryer. If you look closely, the towel on the right is fluffier and its fibres are finely separated. The air-dried towel on the left has its fibres laying flat and almost matted together. In the second photo, this explains why you can see the imprint of my hand on the machine dried towel, but less so on the air-dried version.
So, if you feel like your towels have lost some of their softness, even with appropriate care, then I’d highly suggest trying the use of a drier. Likewise if you are having problems with linting. It might just save you having to buy new towels.
In particular, I want to thank @Eldorado2k for prompting me to make this change. This is the beauty of forum life, we can learn from each other.
Our dryer is broken but when fixed i will try this method for the paint work microfibre cloths.
And to all the people waiting for a "Full Load" sometimes it feels good to let out a load every now and again.
