Mike,
I watched the Meg's video about the Meguiars DA Microfiber Correction System. In the video it was explained that cleaning pads often was essential.
My question is, how often should the cutting pad be changed? Does the MF cutting pad enable you to simply clean often and use less pads?
I do not have a pad cleaner and I'm trying to figure out how many Cutting pads I need per vehicle.
Thanks!
Here's the deal... having more pads on hand is better than having a few pads, that's a general rule of thumb so let your budget be your guide.
I always see people post the best way to clean a microfiber pad is with compressed air, as using an air squirter to blast air at the pad and this is the best way.
The thing is though... not everyone has an air compressor...
I show 6 ways to clean a microfiber pad in my
how-to book on pages 89 and 90,
1. Compressed air using an air squirter.
2. A bug sponge - Due credit to
Joe Fernandez for this idea.
3. A nylon pad conditioning brush.
4. Pad washer.
5. Machine washing.
6. Hand washing.
Of course the washing methods kind of take the pad out of action until they dry.
As for how many pads do you need to buff out a car?
If you're going to do this for money then speed is key to maximize profit while minimizing time buffing and the first step is the step that takes the longest no matter what type of tool, pad or product you use so that ties directly to your cutting pad question.
More pads are better. It's faster to switch to a clean, dry pad after each panel than to try to buff out an entire car with just one or two pads.
PLUS you'll find your pads will last longer because you're not punishing them by pushing them to the limit each time you buff out a car.
Meguiar's recommends a max OPM of 4800 OPM which is the 4.0 Speed setting on the G110v2 and an important part of the reason why they recommend this speed setting is to avoid generating too much heat which will cause the adhesive used to make the pad to fail.
Most guys operate under if a little is good, more is better and that applies to buffing speed to but it's not what the manufacturer recommends.
So if you're going to be buffing out average sized passenger cars, suvs and trucks, I'd recommend getter 6-8 pads or 3-4 packages of Meguiar's Microfiber pads as they come in 2-packs.
