Microfiber Cutting Pads
Thanks Mike!
One more question, what setting would equal Speed 4 on Griots DA? I've read that the Griots DA is a little more powerful so I'm not sure the speed settings are the same as the G110.
The GG has more Torque; this will not affect the suggested Speed (OPM) for these pads.
Mar 11th, 2011, 03:20 AM #4
Merlin
Registered Member
Join DateSep 2009LocationSunny South FloridaPosts125Rep Power6
Re: OPM speed settings for the DA polisher?
Well after some research here's what I found.
OPM's for Meguiar's G110v2
Speed Setting 1 - 1800 opm
Speed Setting 2 - 2800 opm
Speed Setting 3 - 3800 opm
Speed Setting 4 - 4800 opm
Speed Setting 5 - 5800 opm
Speed Setting 6 - 6800 opm
OPM's for G100/PC
Speed Setting 1 - 2300 opm
Speed Setting 2 - 2350 opm
Speed Setting 3 - 2600 opm
Speed Setting 4 - 3280 opm
Speed Setting 5 - 4780 opm
Speed Setting 6 - 6100 opm
Speed Setting 1 - 2560 opm
Speed Setting 2 - 3250 opm
Speed Setting 3 - 3950 opm
Speed Setting 4 - 4600 opm
Speed Setting 5 - 5550 opm
Speed Setting 6 - 6700 opm
OPM's for Meguiar's G220
Speed Setting 1 - 2760 opm
Speed Setting 2 - 3450 opm
Speed Setting 3 - 4150 opm
Speed Setting 5 - 5750 opm
Speed Setting 6 - 6900 opm
OPM's for UD Machine
Speed Setting 1 - 2660 opm
Speed Setting 2 - 3950 opm
Speed Setting 3 - 4130 opm
Speed Setting 4 - 4900 opm
Speed Setting 5 - 5240 opm
Speed Setting 6 - 6540 opm
OPM's for Griots 6"
Speed Setting 1 - 2500 opm
Speed Setting 2 - 3300 opm
Speed Setting 3 - 4200 opm
Speed Setting 4 - 5100 opm
Speed Setting 5 - 6000 opm
OPM's for PC7424XP
Speed Setting 3 - 4000 opm
Don't take it for gospel and if there are any changes please reply.
Merlin
Registered Member
OPM's for G100/PC
OPM's for Griots 6"
OPM's for PC7424XP
That is awesome! Thanks!
Merlin
Registered Member
Thanks Allen for digging up Merlin's post on this topic. This was exactly the info I was thinking of to answer the OP's question.
Big picture is this... higher speeds over time create a lot of heat in the center of the backing plate that transfers to the microfiber pad and with enough time will cause them to fail.
More pads = Better
You'll work faster and your pads will last longer overall.
