Microfiber Pad Recommendation
Are these Griots Fast Microfiber pads different from the Boss Microfiber pads with a hole?
And if anyone could post a quik pic of the Boss Microfiber Pads from a sideview I'd appreciate it. TIA.
I'm curious to see what they look like if there's no foam interface on those pads.
Minus the foam portion they are same. MF nap attached directly to the Velcro area.
So basically just like the Meguiars Microfiber cutting pads vs. Megs Extra Cut Microfiber pads.
Yes.
However The nap is taller and plusher for GG MF pads.
Face view with flash on
And a side view :
Keep in mind though they won't contour well on curves and would work effectively on flatter surfaces. You might have to do a bit of pad lifting when moving across bonnet lines.
I have a set of Megs Extra Cut Microfibers.. I've only used them once.
exactly. to me the fiber on the Groit's pads are better, it doen't mat down as fast and it cleans up really easy.
