Microfiber Towel-Cloth Machine Wash Detergent for cold water best
PeteT19640
Member
Hi I need to get some of this and was wondering is there any preferences or best ones?
Thanks in advance
HD Towel Clean. Probably the most recommend on this forum (Micro Restore is also popular).
I've used Towel Clean. It's pretty good stuff. I especially like it diluted 1:3 to clean foam pads.
Hi thanks for your reply
Do you mean 3D Towel Clean?
Can it be used with cold water?
For washing machines?
Thanks again
I’ve never heard anyone mention a particular microfiber detergent working better than another in cold water. I don’t think it matters. It works well whether you do a hot or cold water wash.
3D Towel Kleen works very well, and with the amount needed per wash, the gallon is a great price point. At least for me.
I've never even tried cold water. I always wash warm/warm.
HI thanks for your replies
With the washing machine would I use Low or Medium or High for the wash cycle?
They say to fill the machine then add Towel Clean?
I would be adding to the water directly not the detergent dispenser?
Thank you
I too use Towel Kleen. I wash all my MF towels on warm, but they could probably handle hot water too.
My laundry machine is a non-HE top-loader, so once it's full with water I add the detergent.
Not sure what you would do with an HE machine that uses a dispenser. I haven't tried, but I would think an HE machine isn't as good at cleaning detailing products from MF towels because of how little water they use.
I use hd towel clean with hot water. Dry on medium, unless it's pfm, I air dry those .
I use the PoorBoys with cold water, a bit of All Pure(I think that's the name) and vinegar in the rinse cycle. Towels come clean, but I also presoak them in 10-1 apc before hand if they have tough stains.
By no means am I knocking you for how you clean your towels, but why do you feel the need for the All? I have been using Poorboy's for awhile, and have never added anything for the wash or rinse, and my towels come out perfect every time.
Hi thanks
What is a "HE" washing machine, I have a top loader?
Ok so for Towel Clean use the high water setting? How much Towel Clean would I use per load?
Thanks
3D Towel Kleen. Awesome stuff and about the same price as regular detergent. I've done side by side tests with soaking my buffer pads in 5 gal buckets, Towel Kleen vs All Free and Towel Kleen works much better at breaking up the products, especially ones like D166 or HD Speed, the latter being touch to remove from pads and it works great.
