Hot FTW. You may get some color bleed the first wash, so washwomen beware.
lol happened to me when I washed all my MF towels and foam pads together. My new white pads turned into tie-dye pads lol. I dry and wash on hot
Vinegar can do a couple of things. Used in the rinse cycle, it helps get the excess soap out. I think it has something to do with softening the water. The reason people think it softens their towels is because leftover soap on the towel will make it feel stiff.
The other thing it can do is set the dye in the towel which helps with bleeding. When I get new towels, the first thing I do is wash them in cold water using vinegar instead of soap. Some towels are real bleeders, so it doesn't work all the time, but in most cases it does.
Get the white distilled vinegar. I use it for doing my regular laundry too. Just put it in the Fabric Softner dispenser. If you like using a Fabric Softner on your clothes, use dryer sheets instead.
Good to know for the vinegar, thanks for the tricks!
2 other newbie questions here:
- What quantity of vinegar do you use?
- What is a MF detergent? Do you have an example of it?
Thank you!
Chuck!
