Regardless of the area, if you want to try a really safe way before rubbing any chemical to the area or chipping at the sap with something like a plastic razor blade, then here's a suggestion.
Water
Water is very safe. It's also a universal solvent in that just about anything when exposed to water
long enough will tend to disintegrate verses become stronger.
The key for something like this is to keep the water on the sap and you can do this with a microfiber towel. I'd suggest using warm water too.
Take a clean microfiber polishing cloth, fold it four ways to create a thick, plush wiping cloth.
Wet the cloth with water until the entire cloth is saturated but not to the point where water is running down the hood. The idea is to have plenty of water present to soak into the dried bird dropping.
Then let it sit.
You could also try keeping the water warm using a hair blow dry or a heating pad.
The idea being to soften the sap to make it easier to remove without damaging the underlying surface or marring it in any way.
The above is the
safest approach I can think of and there are certainly many more ways to approach this but each other method starts to bring more potential for problems with it.
So you asked for the safest way and the above I think qualifies.
Besides the above, rubbing like Bobby said with some turpentine, which is a solvent made from the sap taken from Pine Trees, (I think), plus a plastic razor blade should work.
Or like Mike Lambert said, some IPA, the strongest available is 91% from any drug store and then dab a microfiber towel with this and gently rub on the sap marks.
Here's the deal about sap, because the trees it comes from are all different... different types of sap break down differently. Some will re-liquefy with water and some won't.
You don't know what you can do until you try.
In this example you state,
DP )* GXP said:
the plywood above the car had sap come out of it
I've worked in a Plywood Mill in Oregon, Simpson's to be exact. I've performed every aspect involved in making a sheet of plywood from pulling on a Green Chain to running the saws that trim and finish the final piece. In-between all these functions I've also been the Glue Mixer and worked in the lay-up of making plywood.
It's possible what dripped off the plywood is sap and it's possible what dripped off the plywood is glue or resin. If it's amber or a clear yellow or gold it's probably sap and if it's reddish in color that's probably glue.
Can you take a picture?
Hope the above helps....
