When I detail engine bays, I spray WD-40 on all wiring harnesses and electrical areas....
Sure appreciate your sharing that. Seems obvious after you put it out there. I have been dreading my first engine detail, feel better now.
i clean my engines:Sure appreciate your sharing that. Seems obvious after you put it out there. I have been dreading my first engine detail, feel better now.
Just out of curiosity, if you were going to use this as a way to keep bugs from sticking to the front of a car wouldn't it be safer to use somthing like a straight weight 30 oil? I would think that if you used the one with no detergents or additives it would be safer for the paint. I would still prefer to use somthing like dg 105 or fk1000, but in a pinch I think it would be safer than the wd-40.
Here in Texas WD-40 is the favorite choice for men as an aftershave......and in all truth many use it to repel bugs while out in the field.
Be cautious when using WD-40 on re-paints. It can possibly soften paint as I found out the hard way one time.
Generally it is safe, even on skin to repel pesky skitters, so it should not be harmful to cured painted surfaces.
Anthony
We always kept WD-40 around a touchless car wash that I used to work at part time. Every week or so someone would spray there engine and then the car would not start or run really rough.
We always went to the spark plug cables everytime. You could see it sparking with the moisture that was trapped where the plugs and cables met. One quick whoosh with WD-40 an all was better.
Did the same thing for farm equiptment. Sprayed WD-40 first then washed then re-sprayed.
i also have a locksmith friend that swore against WD40 and locks, apparently the oils mix with dirt ...
...but I've heard you don't want it on the paint...
^^Matt, I'd try some white lithium grease.
At work we use either Kent total rubber care or wurth rubber care. Both work quite well at freeing up sticking windows. As long as there isn't too much old grease and dirt in the tracks. I use it bi weekly on my fit as maintenance. I just give it a light spritz along the track and get the excess out with q tips. Both products work pretty much the same. Both of them even smell the same. Also neither contains silicone so they shouldn't attract more dirt.
some people used to use old gasoline to clean their hands of oil too.... i wouldnt say wd-40 is a good choice to use on your skin to repel skeeters though... id be worried about possible chemical burns from letting it set on your skin and evaporate.
