Shiny Lil Detlr:
That is absolutely reasonable -- however if you *know* your targeted marketing will reach an 80-90 mile radius you should calculate your prices and set the outward limits of your service area accordingly. If you get beyond that level, THEN you start charging extra.
I do not know what percentage of my customers will be from where, so I have no basis for adjusting my prices accordingly.
Here is my current exterior service/price list. Maybe someone would be willing to make some suggestions?
Our mobile automotive exterior detailing services:
We offer two standard levels of exterior detailing treatment, along with being able to create a custom treatment to meet your specific needs.
Base Package:
A.1):This service begins with a high quality and gentle hand washing using a high quality automotive wash and a micro-fiber wash mitt. - Rinseless option available.
B): A clay bar is then used, to gently and effectively remove surface contamination from the paint's surface.
C): The automobile is then thoroughly dried using a waffle-weave micro-fiber towel.
D.1): Paint is then treated to the gentle application of a high quality carnauba wax, using a DA polisher and a soft foam applicator pad. - Sealant option available.
We primarily use a DA polisher for wax application, due to its ability to spread wax very evenly and thinly. This allows a uniform and intense shine and depth to come through to the surface, while providing lasting paint protection.
E): Tires and trim are protected using a high quality tire and trim sealant.
F): Complete interior vacuum.
This service typically takes approximately 3-7 or more hours.
Base Package Prices:
Small size car: Starting at $70.00.
Mid size car: Starting at $95.00.
Large size car or Small size SUV/Pick up truck: Starting at $120.00.
Mid size SUV/Pick up truck: Starting at $100.00.
Large size SUV/Pick up truck: Starting at $180.00.
Extra Large size SUV/Pick up truck: Starting at $240.00.
* Price is based on your automobile's size. (And in extreme cases only, the amount of cleaning required.)
* We will travel the first 60 miles from Honesdale, PA free of charge. Add $0.33 for each additional mile.
Base Package Plus Basic Polish Package:
This service includes steps a through f from the Level 1 service and adds the following.
G): Paint polished to an beautiful finish, that is vibrant and full of life. This polishing will also remove some
very minor paint swirls and some
very minor water spots.
This service usually takes approximately 5-9 or more hours.
This service only removes some
very light swirl marks and some
very light water spots. For deeper swirl marks and water spots, we suggest our paint correction service.
Base Package Plus Basic Polish Package Prices:
Small size car: Starting at $120.00.
Mid size car: Starting at $160.00.
Large size car or Small size SUV/Pick up truck: Starting at $250.00.
Mid size SUV/Pick up truck: Starting at $260.00.
Large size SUV/Pick up truck: Starting at $300.00.
Extra Large size SUV/Pick up truck: Starting at $380.00.
* Prices are based on your automobile's size. (And in extreme cases only, the amount of cleaning required.)
*We will travel the first 60 miles from Honesdale, PA free of charge. Add $0.33 for each additional mile.
Optional exterior detailing services:
A.2): A rinseless wash can be substituted for the standard wash at no additional charge.
A rinseless wash is completely safe for your automobile's paint, due to the special wash agent used and its ability to lift the dirt from the paints surface and trap it deep inside the micro-fiber wash mitt until it is released into a bucket that is separate from the special wash agent's bucket. This is our preferred wash method, as it makes less of a mess of the wash area, only about 4 gallons of water are needed, and can even be performed inside of a garage or car port without making a mess.
D.2): A paint sealant can be substituted for the carnauba wax treatment for an additional $20.00.
A two step paint sealant that provides longer and stronger protection for the paint, can be substituted for the high quality carnauba wax. This sealant process starts with a prep that is applied by DA polisher. The sealant itself is then applied by hand and foam applicator pad. This sealant requires 3-4 hours to dry before the automobile can be driven, and up to 24 hours to cure before being exposed to heavy moisture.
