Modified Foam Cannon
Bubbabuff
My foam cannon broke, the tip was cracked in half, so I did some brain storming and modified the tip so it will take a detachable soap nozzle, I had to make the stainless steel filter smaller so it would fit in the chamber, Works great and I find the spray pattern more consistant.
Wow, that's crazy. I'm about to get mine, but I'm confused. I know its a prewash, but why can't i just take a wet mitt to the car and start washing?
I dont see why you can't take the mitt right to the car after foaming it down, look at how the foam (DP Xtreme) sticks to the car!
You guys interested in one of these "snow" launchers!?!?!
In the UK they use "SNOW FOAM" would that be the same as CW&G or DP extreme??
I've never used Snow Foam but I saw it used in foam cannon videos on Youtube. I'd say that a lot of suds from only 2 ounces of DP Xtreme Foam Formula.
here is a demo of it in action, its a bit humorous.
[ame=http://www.youtube.com/watch?v=LXjLUKh5CEg]YouTube - foam lance demo[/video]
Is that really only 2 ounces? Because i use about 5 ounces and the rest water to achieve those kind of suds.
How did you get the new brass fittings to hold securely in the old plastic tip?
beleive it or not that is 2 ounzes on armoural soap (cheap$$)
