i have used D120 for a long time. i make it with distilled water, 10:1 as prescribed by the manufacturer. primary uses are INTERIOR glass and we also use it around the house for light cleaning - mirrors, counters, windows, stove, etc. it's so ridiculously cheap, why not.
i generally don't use it on exterior glass; for that i prefer my go to instant detailer: 50% Opti-Clean, 50% OID. i like that the most since i can clean the trim at the same time (particularly on the windscreen) and have less worry about instilling fine scratches, esp. on windows that have piano black trim. it's especially helpful with bugs and stuff.
ANYWAY, i've thought about D120 and i love everything about it except one thing - it doesn't allow the towel to glide on uncoated glass when wiping dry and that can be a pain on certain interior windows. the towel can sort of stick on interior glass if the glass is "squeaky" clean. i love my Glass Master Pro tool, that thing makes life SO much easier on many different types of front/rear glass, but even with it, there is a certain degree of drag with D120 that i wish wasn't there. the towels i use are the Microfiber Madness Cloudbuster or, if that is too thick for certain areas, i'll use the old OPT glass towels. they are super thing and almost abrasive in texture (but aren't).
the solution i've settled on for improving D120 has been adding OID. that was a natural progression since OID is insanely slick and when diluted properly, can be very easy to manage re: streaking. i played with a few different concentrations and i've found ~1/3 of OID made with double the distilled water as prescribed (so, 6:1) and ~2/3 D120 @ 10:1 is the sweet spot. it's just enough OID to allow the towel to glide effortlessly as you buff, but not too much whereas you may end up with some light streaking.
i strongly urge you to try it if you have the materials available. i am a stickler for clean glass and this has been one of the greatest solutions to making life easier in that regard.
