Swirls are both baffling and cunning. One person can use one set of products have no no marring - while another can use the same products with less than stellar results.
The variables are numerous. Remember, some people have had towels scratch their paint. Brand new soft towels. While others have used the same towels with no issue.
I've used this brush like a zillion times without issue. It's a very well made high quality brush. In fact, my local pay and spray car wash has these same brushes installed (flow through version) in their bays for commercial use. While this doesn't attest to wether or not they "scratch", it does attest to how well made they are.
Their are so many variables that could be causing the OP's issue:
1. You have super soft paint. Paint so soft it can mar with certain towels. This is possible, but not likely if the issue is showing up on multiple cars or cars previously washed by the OP multiple times without issue.
2. You received a defective brush. Something in your brush's construction is marring your paint.
3. You are not soaking your brush long enough prior to use.
4. There is some local contaminant in your area (some type of "dirt"), that just doesn't play well with this wash media.
5. Your technique is "off". Too much pressure, not enough pre-rinsing, not enough soap, etc... are all possibilities.
6. Swirls are completely unrelated to the brush. For example, maybe one of your drying towels became contaminated - coincidently, the same time you started using the brush.
7. Don't know the OP's experience or skill set, but could be light swirls were there the whole time, but were only noticed after scrutinizing the paint after spending so much on a brush.
****please support trans-species humans.
