Mike@ShineStruck
- Apr 17, 2015
- 1,482
Awesome work there
You should post a video with your technique!
Have some questions:
- What's your mobile setup?
- For headlights with deep scratches, do you sand them until they are gone?
- How do you deal with headlights that have cracks on them?
So you do all the sanding by hand? What kind of pad do you like for polishing out the sanding marks?
Your results are top notch.![]()
Awesome work there
Always a pleasure to see top quality headlight restoration work, I highly recommend anybody who lives in Oklohoma City to use only your service (as I havn't seen others work in Oklohoma).
Your restored headlights look so transparent that if you would finish with 2K Clear Coat you would make them look less clear, I think even air when it was not polluted had less exactness, your headlights have a clarity of Purity Vodka I drink tonight 1 shot for your success.
Mobile headlight restoration in the Oklahoma City area OKC Headlights - OKC Headlights http://www.facebook.com/okc.headlights
Set up is GG6 with a 3" BP, sanding discs, wet/dry through 3k grit, WG polishes and yellow/orange pads.
Deep scratches can be minimized but not worth my time to try an remove them. Customers completely understand before I start.
Cracks cannot be fixed at all. If there's no sharp corners that might catch the pad, then I go ahead and do them.
As far as the video, I'm not very computer savvy nor very photogenic. Maybe later on I will put something on Youtube.
Thanks for the info!
Last requests
- what sanding discs are you using? I'm deciding between Meguiar's, 3M and MIRKA
- how many headlights does a disc last?
- how do you power your GC6 while doing mobile?
Holy Cow are those some Flat Out AMAZING Results G35 Coupe!!!!!!!
Way to go, and thanks for sharing!
So you're Final Polish is the Wolfgang Uber, and then you Directly follow with the OL?
Continued success to your business and talents Man!
Ray
These before and afters are so satisfying. Crystal clear results. You must have some very happy customers![]()
Are you talking about the Range Rover customer from last year?
I think you misunderstood me. I did his Range Rover last year (personal SUV). He was happy with the results so he had me do two of his company trucks recently. Just a repeat customer, not a repeat job.![]()
Quick question would a paint prep product be fine to use prior to coating such as eraser, optimum paint prep or Wolfgang and what not?
