WRAPT C5Z06
- Nov 12, 2009
- 12,615
Does it have any wax or sealant properties?
That's what I'm looking for. What are some other "pure" QD's?No it does not, it is a pure QD as I call it.
On the same page as the DP Waterless Wash would be ONR at QD strength.
DLB
OP is asking about a QD with no waxes or sealant...why are you talking about paint cleaners? Just wondering.Megs #34 final inspection is body shop safe so it is a pure QD as well, i use this all the time to remove polish and inspect paint, Menz Top Inspection is also a inspection spray as it removes polishing oils but would not use it as a QD on a waxed surface as it does have a alcohol smell to it. But Menzerna stuff works great and I use it as a final wipe down after all polishing is done and use Megs #34 between polishing steps as it is much cheaper. DP Waterless wash is also another one.
how would ONR at QD strentgh compare to DP 4 in 1 diluted to QD strength? Are they about the same?On the same page as the DP Waterless Wash would be ONR at QD strength.
DLB
Showtime has no appreciable protection, but it is well lubricated and smells nice too.
You seem to be missing the point. You are recommending two products that will remove waxes/sealants/polishes when the op wants a QD with no wax/sealant just to clean and not to remove his existing LSP.Just stating that QD's with no wax/sealant or any type of gloss enhancing product is something that will work well to remove polishes to inspect paint. I use them for that purpose and that is my experience with those two products. I suggested 2 products that the OP was looking for and gave my experience of them. What I used them for may be different than he is looking to use them for but still saying they are two good products.
Exactly.You seem to be missing the point. You are recommending two products that will remove waxes/sealants/polishes when the op wants a QD with no wax/sealant just to clean and not to remove his existing LSP.
I will look into this. Thanks. :xyxthumbs:Megs #34 will not remove wax/sealants and is 100% safe to use on LSP will not harm it at all.
Megs #34 will not remove wax/sealants and is 100% safe to use on LSP will not harm it at all. Menzerna says there Top Inspection will not harm LSP also but I question that a bit.
Exactly what I'm looking for. Thanks! :dblthumb2:As others have mentioned, Showtime does not contain any wax, or offer paint protection. It's a gloss enhancer and great for removing fingerprints, light dust, etc.
