Also i kinda cringed when you mentioned you put premium gas in your tank. Premium doesnt mean the gas is better, it simply means that the fuel ignites at a different stage than other grades. This comes into play with higher performance engines. 87 octane ignights under a certain compression at a certain temperature when your pistons are at a certain point in the cylinder. Putting a different octane in your engine changes when the fuel actually ignites. Your engine is set by the factory/computer to ignite the fuel at a certain point. So either its ignighting sooner or later with premium and best case scenario your computer will adjust and compensate. either case you are throwing money away. Heres a thread I found on a CR-Z forum for you.
real quick heres another article on the premium in regular tank
Do You Really Need Premium? - Edmunds.com
The "minimum" octane is 87 for my car, so using 93 isn't going to hurt the car one bit. I ran premium in my 2010 Fit and the winter mileage went up from 22-23 mixed driving to 28-29 using premium, from that day I was sold. If you think about it, the computer detects better fuel and adjusts things accordingly, so the added mileage should be from a slight increase in torque, which I did start to feel after a while in the Fit, not to mention I added an intake some time after that, so ofcoarse the computer would once again adjust to that as well.
Its about .30 more a gallon here, so if I were to run the tank all the way down, the extra cost would be $3.00, no biggie IMO.
Will, thanks for the compliment on my car and good luck with that name for your company!
