richy
- Mar 27, 2007
- 5,158
This customer approached me after ordering his Tesla. He wanted it coated with CQF and I was excited to do it as this was only my second Tesla. I still had fond memories of the first one. This car was silver. I was thinking about what the one step polish combo would be that I would do to this car a few days ahead of getting it (I do a one step polish for my new car coating package). I had considered two divergent strategies: either softer pad with a medium polish or a harsher pad with a softer polish. I'll share in a minute what those were and how they worked.
Here it is as it arrived:
When I saw the car, I knew I had to pull the wheels. In all honesty, these wheels would really benefit from having the barrels coated as well. Luckily the customer agreed. First up was to clean the wheels, barrels and wells. The barrels had some tar in them already and Tarminator got rid of that in short order. That was followed by Zep Citrus. This process was done for the barrels and the faces. The wells were cleaned with LATA. The tires were cleaned with Zep 505.
Next the car was washed with DG 901 followed by a secondary decontamination wash with IronX paste. It was then brought inside and was blown off with my Master Blaster. The car was then clayed using the Speedy Prep towel.
I had asked the customer if he knew what the wheel torque specs were and he thought it was 120 ft/lb. That seemed high to me. I went onto a Tesla forum and then posted the question on FB. Wes (who has literally done hundreds of these) responded quickly and confirmed what the forum info was: 129 ft/lb. Wow, that's high! Each wheel was removed and the barrel was intensely cleaned with Tarminator if need be and ONR to make sure it was perfectly clean. After that, it was chemically cleaned with DG Squeaky Clean to ensure a proper bond with the CQF. I am a firm, firm believer in the importance of using SC prior to coating. The barrel was then given 2 coats of CQF which was flash cured. I shot a video of the flash curing to show CQF and Americoat installers how it helps. The wells were then shot with Permanon. The calipers were also coated with 2 coats of CQF even though it did not help their appearance due to the type of paint used on them (not glossy). The faces were cleaned and coated in the same fashion.
Here is the well all done:
Here is the face all done:
Here is another shot showing the barrel:
Each wheel was re-installed and torqued to 129 using my Snap On torque wrench.
One thing that I do (because I'm nuts) is coat the Tesla key fob. I just think it's the coolest damned key I've ever seen and deem it worthy of being coated, so I do. Here is the key for this one having been coated with a double coat of CQF:
Back to the single stage polishing. My goal was to make the paint shimmer. I wanted to try my D300 with an orange B/F pad and it created a pretty damned nice finish. I honestly thought that was what I was going to go with. The other option I was considering however was to use the aggressive yellow B/S pad with M205. Now, before you go off on how hard and unforgiving that pad is, remember this: I first get it soaking wet with hot water and then wring it out and spin it on my rotary at 3,000 rpm. It makes it damp and more importantly, very pliable. It literally changes how the pad feels and acts IMO. I combined that with M205 and did a test spot. BABY!! Check this out:
So, the car got that combo followed by DG Squeaky Clean via green B/S pad. Both stages were done with Flex 3401.
The only real mark I found on the car was the RR tail lens. It had a small scratch in it. I think this pic captures it. I also shot the surrounding area in an attempt to capture on camera the before and after difference of the polishing combo.
205 got rid of the scratch:
Surrounding area:
The paint and glass were all double coated with CQF and then baked via IR lights:
The windshield was coated with Fly-By-30. The trim was coated with DLux. The tires shot with Opti Bond at 100% through my mini air gun.
Surrounding area:
