artofdetailing
- Sep 13, 2010
- 437
Hi Guys,
Just want to remind my fellow forum members a couple of really important things when drying the car
1. Always begin the drying process with a wet waffle weave towel. By wet I mean completely soak the towel with clean water and then wring out as much as possible. Using a dry towel Can cause towel wipe scratches. Yes, clear coats these days are that sensitive.
2. Wipe down the car from top to bottom and work in straight lines. When the towel is unable to absorb more water, wring it out and keep going.
3. The car won't get 100% dry this way but rather about 90%. For the remaining little bit of water, use a detail spray or spray wax/sealant with a dry PLUSH microfiber. Preferrably 400gsm and up.
4. If you have the money, buy a Metro Master Blaster. You will need to upgrade your circuit to 20amp of better to use all 8hp though.
This way of drying has really helped me out and I think you will have great results this way too.
icture:
