My First Subaru (PICS!!!) - 2005 STi Paint Correction and Quick Photo Shoot
I'm impressed with the turnout but more so on your prep work.
Iron-X I never used, and I've been detailing cars for years.
When should I use it and what is it for? It removes what?
Silly questions but I'd like to know:)
Safe for paint I assume?
Iron X is a great product... I won't do a full detail without it. I was skeptical at first, and did not purchase it for a while due to the price, but it is great.
Use it after washing, but before claying. It works by dissolving the bonded iron particles that are on the surface (from things like fallout, brake dust, etc). You simply spray it on, let it dwell, and rinse it off. It starts clear and turns purple as it reacts with the iron. The only negative I have found with it is the awful smell. Only use it outside or in a very well ventilated area. I purchase it by the gallon and distribute it into a 32 oz spray bottle as needed. It saves a lot of time when it comes to claying because a good amount of the contaminates have been removed with the Iron X. It can also be useful on wheels to help with brake dust. More info below.
www.detailedimage.com said:
Product Information
This is the MUST have product for ALL detailers!
Remarkably quick and effective cleaner for the exterior paint and wheels
Mist Iron X on the exterior and watch it safely dissolve embedded iron deposits
pH balanced and gentle formula safe to use over virtually the entire exterior
Turns a deep and dark red color as it dissolves particles stuck to the surface
Cherry scented with improved formula!
Product Description
If you need the most effective exterior cleaner on the market the CarPro Iron X Iron Remover is the product you simply must have! With one quick treatment you can remove the vast majority of contaminants on your vehicle's exterior surfaces with little to no work. This gentle formula is pH neutral yet incredibly effective at removing build ups even the naked eye can't see. Mist it on the paint, wait 5 minutes and wipe it with a damp sponge or skip the sponge and move on to a thorough rinsing. Upon completion you'll be stunned at how much has been removed with so little effort. It can reduce the amount of contaminants your clay bar can remove by as much as 80%. This will save you a ton of time in the clay bar process and enhance the results from your polish, glaze, sealant and wax used afterward. The improved formula also has a cherry scent now! So stop using multiple products to achieve mediocre results, pick up the Iron X today you will love it!
To use this product we first recommend washing the vehicle to remove the loose particles. With the vehicle cool to the touch and in the shade shake the bottle thoroughly and mist it on the exterior of your vehicle. We target the wheels and exterior painted sections as that is where it's most effective. It's designed to be safe on all trim and the rest of the exterior but with any new chemical you can do a test spot if you want to be certain. Wait five minutes and wipe the area down with a damp sponge and you'll see the formula turn to a deep and dark red/purple color. After that you can remove it with a damp cloth or thoroughly rinse the vehicle down and you are done. The surface should look and feel much cleaner now!
Tips: Do not let the product fully dry on the surface when possible and make sure you avoid direct sun during the process. Avoid spraying brake calipers and work in a well ventilated area. We recommend wearing rubber gloves and washing your hands right after to be safe. Average usage for an average size car is about 100 - 150 ml for a full cleaning.
