Andre
Super Moderator
- Sep 3, 2013
- 167
Race Ramps 2 Piece Car Service Ramps - 67 Inch
There has been a lot of talk about Race Ramps and it was time to put them to the test. My mustang was a perfect candidate for the Race Ramps because it has a stock ride height.
Autogeek.net
"Race Ramps 67 inch 2 Piece Car Service Ramps have a gentle, 10.8 degree angle for your low clearance vehicle -- but don't let that "gentle" stuff fool you. These solid core design ramps are the toughest around, supporting up to 3,000 pounds and tires up to 12 inches wide. Whether you've got a Corvette or other low clearance vehicle, this low profile car ramp will get the job done.
The 67 inch Race Ramps XT are ideal for oil changing, car detailing or other routine maintenance. Expect to be surprised, because you won't believe how easy it is to drive up the ramp.
These lightweight, low profile car ramps easily lift your car 10 inches off the ground, but they weigh only 15 pounds each, meaning that doing maintenance on your low clearance vehicle won't be the usual chore (no more heavy blocks of wood!) Most of all, our 67 inch Race Ramps are safe and Unscootable, hugging the ground and never slipping or sliding no matter what the ground's like -- grass, dirt and yes, even ice! If you're working in the garage or in the driveway, like all Race Ramps, it won't dig into, scratch or blemish your floors."
Specs:
Advantages:
How nice is it to purchase something and see "Made in the USA" on the box? Doesn't happen too much anymore. Thanks Race Ramps
Just to make sure, I measured my clearance
Next I lined up the Race Ramps and hit the gas
Getting up on the Race Ramp was really easy, I took it a little slow because it was my first time. But other than that, I would say anybody can easily drive up on these ramps. It has a lip at the end of the ramp and it was very clear when I had reached the top.
I was very shocked at how much clearance was gained with the car being 10 inches off the ground. I could easily get under the car and do an oil change for instance
Race Ramps are lightweight and easy to store, not to mention very easy to use. Look at that, I'm holding them up without any effort and I'm not even that strong :laughing:
Conclusion:
If you are going to be under your car often, I would highly recommend these Race Ramps. The material that they're made of is what shocked me the most. It's lightweight but durable as heck. I was very surprised with these ramps and will recommend them to anyone that works under cars. I'm sold!
Race Ramps Vehicle Ramps
Autogeek.net
Specs:
- 67 inches long, 14 inches wide
- 10 inch lift height with a 10.8 degree incline
- 1 set supports up to 3,000 pounds
- Includes handy straps for carrying and storage
Advantages:
- Special construction — won't scratch or mark your floors!
- Lightweight — easy to carry and maneuver
- Solid core — no holes or hollows for your favorite spider to live in!
- Unscootable! Won't slip or slide, no matter the surface
Conclusion:
