My pimped out garage
Any electricians in the group? In my garage makeover, I want to convert a single regular light bulb fixture into a series of 8' fluorescent fixtures. How many 8' fluorescent fixtures can you connect to a single light bulb fixture before it becomes a hazard?
If you take the number of watts in the flourescent lamps, add them up, divide by 120, that will tell you how many amps of lighting you can do. Most garages do not have a separate circuit (usually 15) for the garage. My current garage is 22 x 21. Before I switched out to high output flourescent warehouse fixtures, I had 6 8'strips and 6 4' strips. Be sure to get cool white bulbs, as warm white have a yellow tint to them.
copy pasted... Hope it helps
Do-It-Yourself Repairs and Basic Wiring Projects:
Planning a Circuit
By Terry Peterman, the Internet Electrician
Summary: Planning a circuit in your home requires examining some basic rules regarding the number of lights permitted on a circuit, and recommendations for mounting boxes, receptacles and switches.
When planning to hook up a circuit, whether it is a new one directly from the breaker panel or adding to an existing one, here are some general rules to follow :
Maximum Lights Per Circuit
You are only allowed to put a maximum of 12 lights on one 15 amp circuit, but try for between 8 and 10, if you are combining receptacles and lights.
Remember that switches don't count as outlets. Run a separate circuit for any large appliances, pumps, and motors etc.
Mounting Boxes
Start by marking the studs where you want your receptacles, switches, and lights to be located. Then mount your outlet boxes.
Screws are required for octagon boxes but you can use either screws or nails for switch and receptacle boxes. The important thing to remember is to make the boxes secure because, once the drywall is on, it's hard to re-attach them if they do work loose.
Don't forget that you must leave the boxes sticking out from the face of the stud, slightly less than the thickness of the product that the wall will be finished with.
Mounting Receptacles
Mount receptacles about 300 mm (12 inches) above the floor. The general rule is that a receptacle is required for every 3.6 meters (12 feet) of usable wall space.
You are probably curious as to what useable wall space means exactly...any measurement from the corner of a wall to a closet, fireplace, or to where the door swings open is considered useable wall space but, only if the wall is over 900 mm (3 feet) to begin with.
A receptacle is needed every 3.6 meters (12 feet) along a continuous wall space so that at no time can a cord connected devise be any more than 1.8 meters (6 feet) from an outlet. Also remember that there is no maximum number of outlets, so make sure you have enough, and that they are placed in convenient locations once the room is finished.
Mounting Switches
Mount switches on the inside of rooms opposite to the side that the door opens. Make them as close as practical to the door opening, but not so that the cover plate will interfere with the door casing.
The height is fairly flexible, but should be consistent and practical (any where from 1.1 to 1.3 meters or 44 to 52 inches).
Maximum Wires
Attempt to start your circuit close to the panel and then move out from there.
For a standard sized outlet box you are only allowed a maximum of five (5) wires (excluding the bare ground wire). Keep this in mind when running your wires, as you cannot run power into a receptacle, and then feed two outlets from the same box. This would give you six (6) wires therefore requiring a "deep box".
A standard octagon box used for light outlets has a maximum wire fill of seven (7). These box fill maximums are also based on #14 gage wire which is what you will use throughout 95% of your home.
Common Examples
Here are two examples of how to set up a typical circuit and how you would run your wires. Refer to methods 1 and 2.
Keep in mind these are just examples and your wiring does not have to look exactly like I've shown. This is just a starting point for you to begin.
Once you have an idea of how you are going to run your wires, drill all the holes in the studs. (A 3/4" to a 1" auger bit, driven by a 1/2" drill is the best tool for the job). Make sure to keep the holes at least 1" in from the face of the stud, so that drywall screws or nails cannot penetrate far enough to damage the wires.
Do yourself a favor and leave plenty of slack at each outlet. I recommend at least 300 mm (12").
Then strip the exterior sheath back about 150-200 mm (6"-8") leaving a loop of slack before tightening the box clamps down on the sheath. This is done to ensure that if the wires get damaged in any way, you will still have some slack to work with.
You are required to secure the wires with approved wire staples, within 300 mm (1 foot) of the outlet boxes. Also, every 1500 mm (5 feet) on a free run of wire there must be a staple. Going through a hole in a stud counts as being secured.
Make all the splices that you require at the "rough-in" stage, so that when you come back to install the receptacles, switches, and fixtures, it will be clear as to what wire goes where.
Great looking garage. I bet you want to be in there 24/7.
Nice Z and garage, HOWEVER, that garage will not work very well here in deep south Texas. It's missing ONE LIL Thang. AIR CONDITIONER!!!!!! Here, in hell, we have plenty of nats, mosquitos, flies, HUMIDITY and plenty of heat. Now, if yout garage had an a/c, then, it will ROCK!!!!! LOL :righton:
Liked it!! :Picture:
I would have insulated the walls so I could comfortably do light detailing during the winter months. I'm originally from Marquette, MI. I would have definitely insulated the walls and put a portable heat/AC unit in there. Other than that, VERY nice looking garage. :D
Nice: your car's very own mancave :)
Speaking of posting mancave project threads: the other message board community I'm active in would no doubt appreciate this same post over there: www.PerfectManCave.com
(Mods: I'm thinking I'm not breaking any rules by posting the ManCave's addy here since they in no way compete with or even deal with anything that might be a conflict of interests for AG. If I've inadvertantly broken a rule I apologize and please delete any offending element of my post.)
I was thinking along these lines but also for the soundproofing qualities of insulation. Some R16 fiberglass rolls keeps any kind of machines you'll use from disturbing the rest of the house (unless it's a completely detatched garage that is).
