budman3
- Mar 3, 2006
- 1,744
I’m not sure if anyone else is confused about diminishing abrasives, but here is my take on the subject. Let’s start off with and example- sand paper comes in different sizes of grits and a quality piece of sandpaper will always maintain that same grit throughout the entire process. Since the grit is the same when you begin and finish, it has constant abrasives. In detailing, many companies have developed polishes with diminishing abrasives. These polishes start off aggressive to cut through damage and then the abrasives break down into smaller particles to create a smooth surface again.
Since you want to save as much clear coat as possible, do a test spot to find the least abrasive method which will remove the damage. You do not want to use a compound that is too aggressive – it will remove the swirling and marring BUT it will also remove clear coat that doesn’t have to be removed. This is why it is key to do a test spot to find a polish and pad combo that will remove the marks but nothing more. Once you become familiar with different polishes and pads, finding a combination will become easier. Many “hack detailers” simply grab a rubbing compound, a wool pad, and a rotary and go at it. Sure the marring will be removed but the clear coat will be as well. Also, if you do not let the polishes break down, you can be left with buffer swirls. Always use the least aggressive method as possible!
Once you find a polish, pad and even machine combo, it is time to work that polish into the paint. Different polishes ‘flash’ or work into the paint for different amounts of times. Experience with the products you are using will useful so you know how long to work it in.
Below are simplified and magnified versions of what is going on when you are polishing with diminishing abrasives in a two step manner. Polishing may definitely take more than two steps, but for simplicity I left it to only two. Possible examples of this type of combo are, and not limited to:
Menzerna Powergloss followed by Nano 106ff
Poorboy’s SSR2.5 followed by SSR1
Pinnacle XMT3 followed by XMT1
Meguiar’s #83 followed by #9
Etc.
So, let me try and explain this a little more. As you see above in step one, the abrasives start off large but when friction occurs, the abrasives begin to get smaller and smaller. If you stop before the abrasives have had a chance to break down, you will be left with micro marring, which could have been removed if you kept on polishing. It is possible to finish a compound off in just one step if you use a soft pad with proper techniques. However, it is likely there are some light marks or marring still left, which is easily removed with a final polish.
The final polish diminishing abrasives (in an ideal world) will start off close to the same size as the broken down abrasive from the compound. Once the final polish has broken down, the abrasives will be very very small. This will remove any marring left from before and will finish off to near perfection.
Again, this is just my personal take on the subject at hand. Let me know if you read anything out of line or if you have anything to add. This isn’t meant to be a tutorial on how to polish rather just some background on something that can get a little confusing.
Etc.
