Centexhokie
- Oct 14, 2010
- 215
I am going to put the paint coatings on followed by the sealant in the next couple of weeks, but I decided this weekend to get started with the wheel coating and the glass coating.
First the wheel coating. I have a 4 post lift so I pulled the wheels off of my MB and cleaned them with Sonax and a Daytona speed brush. The OEM brake pads are terrible for dust so this is more work than it should be with normal pads. Once cleaned, I used a clay bar on the outsides and followed that up with the PBL polish. The polish went on easily and I used microfiber applicator to polish until the polish just about disappeared. I then took the coating applied it with the finger applicators. The coating went on really easily and I probably used too much because I had to use a microfiber towel to remove the excess. It went on really easily and the excess wiped off easily after about a 5 minute set up time. I repeated the application 24 hours later. Today at work there were a lot of unsolicited comments about my wheels so it does add some shine to the rims. How well it holds up to the dust remains to be seen.
Second, the glass coating. I cleaned the windows inside and out with Stoner's invisible glass spray. My windows are in really good shape so I did not clay them. I then applied the polish to the outside windows with a 5.5" CCS white pad and a GG DA. The polish seems to go a long way and just like on the wheels seemed to disappear after 5-6 crossing passes. I buffed with the microfiber, but really didn't get much off. I then got inside the car to look out and make sure that I didn't miss any spots. I also took a light and examined the windshield, the side window, the mirrors, and the sun roof to make sure that I left no residue. I did, but it buffed off easily. Once satisfied with the result I applied the coating. It again went on easily and I think I used the right amount because there was little buffing required. Like the wheels the value of this will be seen over time.
Easy application even for an amateur.
