emmjay
Member
- Feb 2, 2015
- 848
Hello all,
Before I begin, I must say, I know 100's of you have had amazing results, and I am really happy for you all. But not all of us have amazing results unfortunately.
Onto my review....
Disclaimer: I know that I had made a mistake of not using the WG Paint prep spray properly, which might skew the review against myself, but taking that into account, I will still continue with my review if I may.
PBL V2 - Subject was a 8 year old Honda Pilot, completely a mess (separate show and shine to come)
The SUV was completely polished out using Ultimate compound, on a White Hybrid pad and my Flex.
Sample image:
Weather and surroundings: Covered garage, not fully closed but I have a roof and garage door and one wall. The other two “walls” are open to the path towards my rear garden straight up and to my front garden to the right. Plenty of wind due to the pathway having two walls on either side, towards my rear garden. 100 degrees ambient and 70-80% humidity.
Coating application:
I wiped the whole car down with Paint Prep, but like I said just once, and went to apply the coating. This could have hampered a lot of it but…..
Initial impressions:
1. Okay nice…it’s a spray…it should be easier to apply. WRONG!
The atomization might be a good thing, but, even a slight breeze and most of the product goes everywhere except where you want it to i.e. Overspray. Some of you like this aspect of the coating, I personally hated it.
Okay…I can live with that, I do have a full bottle after all.
2. Not at all user friendly. Flashes within 5 seconds…no joke
I remember Mike@Dedicatedperfection’s video on youtube that I watched close to 10 times and read his review as well. I read Nick’s comment saying that you should use a little more product. So…to be safe…I used 5-6 sprays per section instead of the 3-4 recommended.
The product was so annoying to work with that even when sprayed heavy, it would leave splatter marks. As in where the spray landed, I would work it in and wipe off and can see the splatter pattern, suggesting it was curing as soon as it hit the paint. What a PITA….
I did 75% of the SUV, except the roof with PBL v2. The roof got Menzerna Powerlock.
When I was 60% through, I had enough and called Andre@Autogeek and spoke to him regarding my problems. He said both PBL coatings are extremely tough to work with in conditions that are not temp controlled or indoors, going against all the marketing hype of the easiest coating to use. He suggested I work the product extremely heavy, say 8 pumps where they would recommend 3 and wipe of while still very wet…So I went ahead with that. The product was still flashing Insanely fast!
I felt I could finally work it for more than 5 seconds. WRONG…
Like I said, I thought I could….It was still flashing quick so I spread to a smaller section even when so heavy and wiped off….first wipe, flip over second wipe, grab another towel, final buff. All using a short nap. I used close to 30 towels on the car.
Same area as before:
All in all, I found this product quite difficult to use.
I would like to say, I might…and that’s a big “might”, have had different results if prepped properly, but that would not stop that ridiculously quick flash time.
Would I buy this product again?
No. Maybe if I had a temp controlled garage.
Would I recommend this product to others?
Yes, as long as you have a temp controlled environment, OR at least a garage that is completely sealed , four walls and a garage door. This way run a portable AC unit at least!
Overall impressions: Hard to use, but the finish was SUPER SLICK! My gf doesn’t care as her car looks brand new and she’s not worried about the high spots one bit.
LOL!
Onto my review....
Sample image:
LOL!
