Mike@DedicatedPerfection
- Feb 26, 2011
- 12,365
I have gotten a few PM’s asking how this method is performed and I wanted to put this together into a thread to show case what is going on during this wash. It is a combination of the two washes put together to compliment each other in one wash.
There are variations of this technique will some are the same. My goal was to combine it all together and show in one thread. This is nothing new and I’m sure others may be doing this same thing.
How much water and towels you use depends on how big the vehicle is. It also depends on if you are using a grit guard in your bucket as this will take water space. With the way I am doing it you do not need a grit guard installed in the bucket as you will never have dirty water. I always use one as I do not like the idea of my towels laying on the bottom of the bucket.
You will need one five gallon bucket minimum
One grit guard on the bottom (optional)
Car Wash Bucket - How to wash a car.
3 gallons properly mixed rinseless wash
Meguiars Rinse Free Express Wash, rinseless car wash, no rinse
6 towels to get started.
Chinchilla Microfiber Buffing Cloths 6 Pack
Drying mf towels
Supreme 530 Microfiber Towel 6 Pack
Spray bottle mixed with waterless wash
Wolfgang Chemical Resistant Pressure Sprayer, pressurized spray bottle, pump sprayer
Meguiars Rinse Free Express Wash & Wax D-11501, rinseless car wash, rinseless wash and wax
Spray wax (optional)
Meguiars Synthetic X-press Spray Wax, X-press car wax, Meguiars X-press spray liquid wax, D156
I have my mixture of Meguiar’s Rinsefree Express wash at 1:1 while my spray mixture of Meguiar’s Rinsefree Express Wash and Wax is set at 4:1. You can adjust your ratios to suit your needs. Also, this is just what I am using at the moment. Feel free to use your favorite combos.
Depending on how dirty the vehicle is you may want to go to a coin op and use the pressure wand to knock off the heavy dirt. After thoroughly knocking the dirt off you are ready to get started at the convenience of your home.
Now to accomplish this method, first spray the panel with your waterless wash mixture with a heavy coat of product. You want plenty of lubrication and enough product on the surface to start loosening the dirt buildup. Let this sit for 1 or 2 minutes before starting. It helps to presoak a few panels in front so you wont have to wait for them to saturate.
Next, pull out a presoaked mf towel from your wash solution and begin to make your swipes across the paint. As you continue to make subsequent swipes, lift the leading edge of your mf towel to use a new portion of the towel. When done right, you will have multiple dirt lines across the face of the towel. When the isolated panel that was cleaned, pull out a separate dry mf towel to dry the panel.
With a mf towel folded into two halves, it will give you 8 sides to wipe with. You can change out sides more often depending on how dirty the paint is.
With your dry mf towel, dry the panel and buff to shine. When the entire vehicle is completed with this method you can either stop or start applying your spray wax if you decide for further gloss and protection.
This is the way I perform my washes without a hose. IMO, this is the ideal way to wash your vehicle if you live in an apartment complex, do not have running water, or washing with free flowing water is forbidden.
Don’t forget proper towel inspection after washing your towels in the washing machine.
http://www.autogeekonline.net/forum...ke-phillips/88875-smack-towel-method-stm.html
On the right side is distilled water. This will ensure the perfect wash solution
6 Chinchilla towels
Putting them down to soak. 6 is enough to start with
6 towels standing on end in 3 gallons of water and resting on the grit guard
Dirty towels that were "Discarded"
The amount of water used for 6 towels
The afters
Drying mf towels
6 Chinchilla towels
The afters
